NAME | Description | Attributes | See Also
Syntax |
integer |
Default value |
128 |
Must be set |
No |
Is modifiable |
Yes |
Is multivalued |
No |
Requires restart |
No |
This property specifies the maximum size of the listener's new connection queue. When the queue is full, new connections are rejected.
This property takes an integer.
The value of this property must be at least 1.
This property is used to configure the following features:
The LDAP listener represents the network interface of Directory Proxy Server.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Availability |
SUNWldap-proxy |
Stability Level |
Evolving |
dpconf(1M)
