NAME | Description | Attributes | See Also
Syntax |
enumeration |
Default value |
Default behavior is not defined. |
Must be set |
Yes |
Is modifiable |
Yes |
Is multivalued |
No |
Requires restart |
No |
This property defines the transformation model. The transformation model is determined by the direction of a transformation, in other words, whether the transformation is applied during the request, during the response, or both.
This property can take the following values in addition to the default.
Mapping
Store and forget
Default virtual value
This property is used to configure the following features:
Virtual data transformations create a virtual data view from a physical data view. Practically, you never define a virtual data view. Instead, you specify the transformations that you require and define these on an existing physical data view. A transformation performs a specific action in a certain direction. The direction of a transformation determines the transformation model. When you define a virtual data transformation, you create a virtual attribute that exists only in the context of the virtual data view.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Availability |
SUNWldap-proxy |
Stability Level |
Evolving |
dpconf(1M)
