NAME | Description | Attributes | See Also
Syntax |
string |
Default value |
none |
Must be set |
No |
Is modifiable |
No |
Is multivalued |
No |
Requires restart |
No |
This property specifies the password used for binding to an LDAP data source to check the data source's availability.
This property is read-only. To change the password, use the monitoring-bind-pwd-file property.
The default behavior for this property is as follows: Proxy uses an anonymous access to access the LDAP data source.
This property is used to configure the following features:
The common name of the LDAP data source
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Availability |
SUNWldap-proxy |
Stability Level |
Evolving |
dpconf(1M)
