NAME | Description | Attributes | See Also
Specifies the name of your distribution function within the library named by nsslapd-distribution-plugin. This attribute is required along with nsslapd-distribution-plugin when you have specified more than one database in the nsslapd-backend attribute.
Use Directory Proxy Server, rather than a Directory Server plug-in, for distribution.
cn="suffixName",cn=mapping tree,cn=config
The name of the distribution function.
None
DirectoryString
nsslapd-distribution-funct: alphaNumDistrib
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Availability |
SUNWldap-directory |
Stability Level |
Obsolete: Scheduled for removal after this release |
