NAME | Description | Examples | Attributes
PROPERTY |
VALUE |
Entry DN |
cn=config |
Valid Range |
0 | 1 |
Default Value |
0 |
Syntax |
Integer |
Specifies the level of logging information that should be returned for the server component defined by the nsslapd-infolog-area attribute. A value of 0 means that only default logging information is returned for the selected area. Setting this attribute to 1 enables additional logging information to be returned for the selected area.
nsslapd-infolog-level: 1
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Availability |
SUNWldap-directory |
Stability Level |
Unstable |
