NAME | Description | Attributes | See Also
This attribute allows you to have greater control over the schema that is replicated. The attribute is off by default, implying that the entire schema is replicated. If the attribute is set to on, only schema with an X-ORIGIN of user-defined is replicated. This setting greatly improves the performance of schema replication.
If you are replicating from a current Directory Server to a 5.1 server, you must set this attribute to on. Otherwise the current schema will be pushed to the 5.1 server and the 5.1 server will be unable to restart, due to duplicate objects.
cn=config
on | off
off
DirectoryString
nsslapd-schema-repl-useronly: off
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Availability |
SUNWldap-directory |
Stability Level |
Obsolete: Scheduled for removal after this release |
