Extension properties appear at the end of the sample RTR file.
# Extension Properties # # The cluster administrator must set the value of this property to point to the # directory that contains the configuration files used by the application. # For this application, smpl, specify the path of the configuration file on # PXFS (typically named.conf). { PROPERTY = Confdir_list; EXTENSION; STRINGARRAY; TUNABLE = AT_CREATION; DESCRIPTION = "The Configuration Directory Path(s)"; } # The following two properties control restart of the fault monitor. { PROPERTY = Monitor_retry_count; EXTENSION; INT; DEFAULT = 4; TUNABLE = ANYTIME; DESCRIPTION = "Number of PMF restarts allowed for fault monitor."; } { PROPERTY = Monitor_retry_interval; EXTENSION; INT; DEFAULT = 2; TUNABLE = ANYTIME; DESCRIPTION = "Time window (minutes) for fault monitor restarts."; } # Time out value in seconds for the probe. { PROPERTY = Probe_timeout; EXTENSION; INT; DEFAULT = 120; TUNABLE = ANYTIME; DESCRIPTION = "Time out value for the probe (seconds)"; } # Child process monitoring level for PMF (-C option of pmfadm). # Default of -1 means to not use the -C option of pmfadm. # A value of 0 or greater indicates the desired level of child-process. # monitoring. { PROPERTY = Child_mon_level; EXTENSION; INT; DEFAULT = -1; TUNABLE = ANYTIME; DESCRIPTION = “Child monitoring level for PMF"; } # User added code -- BEGIN VVVVVVVVVVVV # User added code -- END ^^^^^^^^^^^^
Agent Builder creates the following extension properties, which are useful for most data services.
Specifies the path to the application configuration directory, which is useful information for many applications. The cluster administrator can provide the location of this directory when the cluster administrator configures the data service.
Controls the restarts of the fault monitor itself, not the server daemon.
Sets the level of monitoring to be carried out by the PMF. See the pmfadm(1M) man page for more information.
You can create additional extension properties in the area that is delimited by the User added code comments.
