Sun Cluster Data Service for SWIFTAlliance Gateway Guide for Solaris OS
ProcedureHow to Set the Debug Flag for Sun Cluster HA for SWIFTAlliance Gateway
Sun Cluster HA for SWIFTAlliance Gateway has an option file in /opt/SUNWscsag/etc directory that enables you to set a debug flag.
Normally, the debug information for Sun Cluster software does not reside in the log files. You must edit the syslog.conf file to enable logging of messages of level debug. You can edit the syslog.conf to log those messages in another file.
  1. Edit the /etc/syslog.conf file.
    1. Change daemon.notice to daemon.debug.
      The following output from the grep daemon /etc/syslog.conf command shows that daemon.debug has not been set.
      *.err;kern.debug;daemon.notice;mail.crit
      /var/adm/messages
      *.alert;kern.err;daemon.err
      operator
    2. Restart syslogd.
      # pkill -1 syslogd
      The syslogd command forces syslog to reread its configuration file and account for changes.
      The following output from the grep daemon /etc/syslog.conf command shows that daemon.debug has been set.
      *.err;kern.debug;daemon.debug;mail.crit
      /var/adm/messages
      operator
  2. Edit the /opt/SUNWscsag/etc/config file.
    Change the line DEBUG= to DEBUG=ALL or DEBUG=resource.
