To enable Sun Cluster HA for SWIFTAlliance Gateway to make SWIFTAlliance Gateway highly available, additional installation and configuration operations are required. These operations supplement the standard installation and standard configuration of SWIFTAlliance Gateway.
During a standard installation, SWIFTAlliance Gateway is installed with a physical hostname. To enable SWIFTAlliance Gateway to run in a cluster, you must modify SWIFTAlliance Gateway to use a logical hostname.
For information about the standard installation and standard configuration of SWIFTAlliance Gateway, see the appropriate documentation available in the SWIFTAlliance Gateway CD-ROM.
To perform this procedure, you need the server root directory (the path to the application binaries). You can install the binaries on the local disks or on the cluster file system. For a discussion of the advantages and disadvantages of each location, see Chapter 1, Planning for Sun Cluster Data Services, in Sun Cluster Data Services Planning and Administration Guide for Solaris OS.
Create a resource group for SWIFTAlliance Gateway.
# clresourcegroup create [-n node-zone-list] sag-rg |
Specifies a comma-separated, ordered list of zones that can master the resource group. The format of each entry in the list is node. In this format, node specifies the node name and zone specifies the name of a non-global Solaris zone. To specify the global zone, or to specify a node without non-global zones, specify only node. This list is optional. If you omit this list, the global zone of each cluster node can master the resource group.
Create a logical host.
A logical host is required before you install SWIFTAlliance Gateway.
Create the device group and file systems.
Although you can use a global file system, create an HAStoragePlus failover resource to contain the SWIFTAlliance Gateway application and configuration data.
To create a device group and a file system for SWIFTAlliance Gateway, see Planning the Global Devices, Device Groups, and Cluster File Systems in Sun Cluster Software Installation Guide for Solaris OS.
To create an HAStoragePlus failover resource, see Enabling Highly Available Local File Systems in Sun Cluster Data Services Planning and Administration Guide for Solaris OS.
This procedure uses /swift as the path that contains the SWIFTAlliance Gateway application and configuration data.
# clresource create -g sag-rg \ -t SUNW.HAStoragePlus -x filesystemMountPoints=/swift sag-ds |
Bring the resource group online to enable the IP address and access to the storage.
# clresourcegroup online -M sag-rg |
Create the following directories and symbolic links before the installation.
Without these symbolic links, the SWIFTAlliance Gateway application will not be installed in the correct location. You must install the SWIFTAlliance Gateway application in the correct location to ensure failover capabilities.
Perform this procedure on the node where the resource group for SWIFTAlliance Gateway is online.
# mkdir -p /swift/etc/opt/swnet # chown root:swnetg /swift/etc/opt/swnet # chmod -R 0555 /swift/etc # chmod 0775 /swift/etc/opt/swnet # mkdir -p /swift/var/opt/swnet # chown root:swnetg /swift/var/opt/swnet # chmod -R 0555 /swift/var # chmod 0775 /swift/var/opt/swnet # mkdir -p /swift/home/swnet # chown swnet:swnetg /swift/home/swnet |
Perform this procedure on all cluster nodes.
# ln -s /swift/home/swnet /home/swnet # ln -s /swift/etc/opt/swnet /etc/opt/swnet # ln -s /swift/var/opt/swnet /var/opt/swnet |
Install the WebSphere MQ client packages, if required.
WebSphere MQ client software is software that guarantees and load-balances connections between the gateway and remote SWIFTNet Link systems. If you chose this type of SWIFTAlliance Gateway installation and have the appropriate license, install the WebSphere MQ client packages. The WebSphere MQ client package must be installed locally by using the same installation directory on all cluster nodes or zones that can master the resource group.
You must install SWIFTNet Link on the node or zone where the resource group for SWIFTAlliance Gateway is online. You must also install SWIFTNet Link in the directory on the file system managed by the HAStoragePlus resource that you created in Step 3.
Follow the instructions in your SWIFTNet Link documentation. To refer the SWIFTNet Link documentation, obtain the SWIFTNet Link CD-ROM.
Specify the directory on which to install the failover data service: /swift/snl.
Install any patches for SWIFTNet Link, if required.
The Hardware Security Module (HSM) Installation/Configuration wizard starts up automatically when you click Finish at the end of SWIFTNet Link installation. Click Cancel to exit the HSM Installation/Configuration wizard.
Verify that connectivity with SWIFTNet Switch is established by running the SWIFTNet Link selftest command. For more information, see SWIFTNet Admin Services: Operational Interface on the SWIFTAlliance Gateway CD-ROM.
Stop the SWIFTNet Link instance by running the SWIFTNet Link stop command.
Configure and register HSM on the primary node as follows.
Log on to the primary node or zone as the SWIFTNet Link instance owner with the swnet account.
Run the following command:
# perl SwHSMDiskClone.pl -a SETUP |
Log off.
Log on as the SWIFTNet Link instance owner with the swnet account.
Use the HSM administration tool SwHSM to configure and register the HSM boxes connected to the primary node. See the SWIFTNet Link Installation and Administration Guide for UNIX for details.
During the configuration and registration of the HSM, you must enter the boot IP address of the primary node in the SWIFTNet Link host IP address field of the Register screen. This source IP address is used to establish the connection. Do not use the logical host address that is used by the service.
Register HSM on the secondary node or zone.
Switch the resource group for SWIFTAlliance Gateway to the secondary node or zone.
# clresourcegroup switch -n node2 sag-rg |
Log on to the secondary node as the SWIFTNet Link instance owner with the swnet account.
Log off.
Use the HSM administration tool SwHSM to register the HSM boxes connected to the secondary node or zone. See the SWIFTNet Link Installation and Administration Guide for UNIX for details.
During the registration of the HSM, you must enter the boot IP address of the secondary node or zone in the SWIFTNet Link host IP address field of the Register screen. This source IP address is used to establish the connection. Do not use the logical host address that is used by the service.
You must be aware that the only difference between Step 8 and this step is that you configure and register the HSM on the first node or zone in Step 8, whereas you only register the HSM on the secondary node or zone in this step.
Install SWIFTAlliance Gateway software.
You must install SWIFTAlliance Gateway on the node or zone where the resource group for SWIFTAlliance Gateway is online. You must also install SWIFTAlliance Gateway in a directory on the file system managed by the HAStoragePlus resource that you created in Step 3. In this procedure, /swift/SWIFTAlliance/Gateway is being used as the directory. You might install the SWIFTAlliance Gateway patches, if necessary.
Follow the instructions in your SWIFTAlliance Gateway documentation. To refer the SWIFTAlliance Gateway documentation, obtain the SWIFTAlliance Gateway CD-ROM.
Use the logical IP address as the IP with which the SWIFTAlliance Gateway software communicates with remote hosts.
Synchronize all nodes or zones with installation-specific changes to user files and system files.
The ~root/vpd.properties directory has been replaced by the ~root/InstallShield directory structure. This directory structure needs to be copied on all cluster nodes or zones that can master the resource group. It enables you to install patches in the future. Moreover, after every SWIFTNet Link or SWIFTAlliance Gateway patches installation or uninstallation, the synchronization of the ~root/InstallShield directory has to be redone.
Add all entries in /etc/system and /etc/services added by the installation on the first node to the secondary node or zone that can master the resource group. The entries in /etc/system must be applied to the global zone.
Go to How to Verify the SWIFTAlliance Gateway Installation and Configuration.
Perform this procedure on each node or zone that can master the SWIFTAlliance Gateway resource group.
Log in as superuser to a node or zone that can master the SWIFTAlliance Gateway resource group.
Switch the SWIFTAlliance Gateway resource group to the node or zone that you logged in to in Step 1.
# clresourcegroup switch -h node sag-rg |
Specifies that the SWIFTAlliance Gateway resource group is to be switched to another node or zone
Specifies the node or node:zone to which the SWIFTAlliance Gateway resource group is to be switched
Confirm that the SWIFTAlliance Gateway instance can be started.
# su - swnet $ cd /swift/SWIFTAlliance/Gateway/bin $ ./sag_bootstrap -startsag start $ ./sag_system -- status system |
The application starts successfully if the preceding command returns a started status. This status indicates that the SWIFTAlliance Gateway is operational.
Create another SWIFTAlliance Gateway operator with an operating profile that contains only the functions to start and stop the application.
Confirm that the SWIFTAlliance Gateway instance can be stopped.
# su - swnet $ cd /swift/SWIFTAlliance/Gateway/bin $ ./sag_bootstrap stop |
Go to Installing the Sun Cluster HA for SWIFTAlliance Gateway Packages.
