Name | Synopsis | Description | Options | Operands | Examples | Exit Status | See Also
create-jdbc-connection-pool
[--terse={true|false}][ --echo={true|false} ]
[ --interactive={true|false} ] [ --host host]
[--port port] [--secure| -s ] [ --user admin_user]
[--passwordfile filename] [--help]
[ --target target]
[--datasourceclassname classname] [--restype res_type]
[--steadypoolsize poolsize] [--maxpoolsize poolsize]
[--maxwait time] [--poolresize limit]
[--idletimeout time] [--isolationlevel isolation_level]
[--isolationguaranteed=true] [--isconnectvalidatereq=false]
[--validationmethod auto-commit] [--validationtable tablename]
[--failconnection=false] [--allownoncomponentcallers=false]
[--nontransactionalconnections=false]
[--description text] [--property (name=value)
[:name=value]*] connectionpoolid
The create-jdbc-connection-pool command registers a new JDBC connection pool with the specified JDBC connection pool name.
This command is supported in remote mode only.
Indicates that any output data must be very concise, typically avoiding human-friendly sentences and favoring well-formatted data for consumption by a script. Default is false.
Setting to true will echo the command line statement on the standard output. Default is false.
If set to true (default), only the required password options are prompted.
The machine name where the domain administration server is running. The default value is localhost.
The HTTP/S port for administration. This is the port to which you should point your browser in order to manage the domain. For example, http://localhost:4848.
The default port number is 4848.
If set to true, uses SSL/TLS to communicate with the domain administration server.
The authorized domain administration server administrative username.
If you have authenticated to a domain using the asadmin login command, then you need not specify the --user option on subsequent operations to this particular domain.
The --passwordfile option specifies the name, including the full path, of a file containing the password entries in a specific format. The entry for the password must have the AS_ADMIN_ prefix followed by the password name in uppercase letters.
For example, to specify the domain administration server password, use an entry with the following format: AS_ADMIN_PASSWORD=password, where password is the actual administrator password. Other passwords that can be specified include AS_ADMIN_MAPPEDPASSWORD, AS_ADMIN_USERPASSWORD, and AS_ADMIN_ALIASPASSWORD.
All remote commands must specify the admin password to authenticate to the domain administration server, either through --passwordfile or asadmin login, or interactively on the command prompt. The asadmin login command can be used only to specify the admin password. For other passwords, that must be specified for remote commands, use the --passwordfile or enter them at the command prompt.
If you have authenticated to a domain using the asadmin login command, then you need not specify the admin password through the --passwordfile option on subsequent operations to this particular domain. However, this is applicable only to AS_ADMIN_PASSWORD option. You will still need to provide the other passwords, for example, AS_ADMIN_USERPASSWORD, as and when required by individual commands, such as update-file-user.
For security reasons, passwords specified as an environment variable will not be read by asadmin.
The default value for AS_ADMIN_MASTERPASSWORD is changeit.
Displays the help text for the command.
This option is deprecated.
The name of the vendor—supplied JDBC datasource resource manager.
The interface that the datasource class implements. Must be one of javax.sql.DataSource, javax.sql.ConnectionPoolDataSource or javax.sql.XADataSource. It leads to an error when this option has a legal value and the indicated interface is not implemented by the datasource class. This option has no default value.
The minimum and initial number of connections maintained in the pool. The default value is 8.
The maximum number of connections that can be created. The default value is 32.
The amount of time a caller will wait before a connection timeout is sent. The default is 60 seconds. A value of 0 forces the caller to wait indefinitely.
Quantity by which the pool will scale-up or scale-down the number of connections. Scale-up: When the pool has no free connections, pool will scale-up by this quantity. Scale-down: All the invalid and idle connections are removed, sometimes resulting in removing connections of quantity greater than this value. Steadypoolsize will be ensured. Possible values are from 0 to MAX_INTEGER. The default value is 2.
The maximum time, in seconds, that a connection can remain idle in the pool. After this time, the implementation can close this connection. This timeout value must be kept shorter than the server side timeout value to prevent the accumulation of unusable connections in the application. The default value is 300.
The transaction-isolation-level on the pooled database connections. This option does not have a default value. If not specified, the pool operates with the default isolation level that the JDBC driver provides.
You can set a desired isolation level using one of the standard transaction isolation levels: read-uncommitted, read-committed, repeatable-read, serializable. Applications that change the isolation level on a pooled connection programmatically risk polluting the pool. This could lead to program errors.
This is applicable only when a particular isolation level is specified for transaction-isolation-level. The default value is true.
This option assures that every time a connection is obtained from the pool, isolation level is set to the desired value. This could have some performance impact on some JDBC drivers. Administrators can set this to false when the application does not change --isolationlevel before returning the connection.
If set to true, connections are validated or checked to see if they are usable before giving out to the application. The default value is false.
The name of the validation table used to perform a query to validate a connection. Valid settings are: auto-commit, meta-data, or table. The default value is auto-commit.
If set to true, all connections in the pool must be closed when a single validation check fails. The default value is false. One attempt is made to re-establish failed connections.
A pool with this property set to true, can be used by non-J2EE components, that is, components other than EJBs or Servlets. The returned connection is enlisted automatically with the transaction context obtained from the transaction manager.
A pool with this property set to true returns non-transactional connections. This connection does not get automatically enlisted with the transaction manager.
Text providing details about the specified JDBC connection pool.
Optional attribute name/value pairs for configuring the connection pool.
asadmin> create-jdbc-connection-pool --user admin --passwordfile passwords.txt --host localhost --port 7070 --datasourceclassname org.apache.derby.jdbc.ClientDataSource --restype javax.sql.XADataSource --property portNumber=1527:password=APP:user=APP:serverName= localhost:databaseName=sun-appserv-samples:connectionAttributes=\\; create\\\\=true sample_derby_pool Command create-jdbc-connection-pool executed successfully |
Where, the sample_derby_pool is created. The escape character backslash (\\) is used in the ---property option to distinguish the semicolon (;). Two backslashes (\\\\) are used to distinguish the equal (=) sign.
