The Sun Cluster 3.0-3.1 With Sun StorEdge 9900 Series Storage Device Manual provides procedures specific to Sun StorEdgeTM 9900 Series storage devices that are placed in a SunTM Cluster environment.
Use this manual with any version of Sun Cluster 3.0 or 3.1 software on SPARCTM based clusters and any supported version of Sun Cluster 3.1 software on x86 based clusters. Unless otherwise noted, procedures are the same for all Sun Cluster 3.0 or 3.1 versions. Unless otherwise noted, procedures are the same for all supported Sun Cluster 3.1 versions on both SPARC and x86 based systems. See the Revision History for a list of changes to this manual.
This book is for Sun representatives who are performing the initial installation of a Sun Cluster configuration and for system administrators who are responsible for maintaining the system.
This document is intended for experienced system administrators with extensive knowledge of Sun software and hardware. Do not use this document as a planning or presales guide. You should have already determined your system requirements and purchased the appropriate equipment and software before reading this document.
This book contains the following chapters.
Chapter 1, Installing and Configuring a Sun StorEdge 9900 Series Storage Array discusses how to install Sun StorEdge 9900 storage systems and how to configure logical units on Sun StorEdge 9900 storage systems.
Chapter 2, Installing Multipathing Software in a Sun StorEdge 9900 Series Storage Array discusses how to add multipathing software to Sun StorEdge 9900 storage systems.
Chapter 3, Maintaining a Sun StorEdge 9900 Storage Array discusses how to maintain Sun StorEdge 9900 storage systems in a running cluster.
The following table lists the information that has been revised or added since the initial release of this documentation. The table also lists the revision date for these changes.
Table P–1 Sun Cluster 3.0-3.1 With Sun StorEdge 9900 Series Storage Device Manual
Revision Date |
New Information |
January 2006 |
Added information about single dual-port HBA configurations. |
November 2005 |
Qualified the Sun StorEdge 9970, 9980, and 9990 in x86 based clusters. |
September 2005 |
Added support for the Sun StorEdge 9985 array. |
The following books provide conceptual information or procedures to administer hardware and applications. If you plan to use this documentation in a hardcopy format, ensure that you have these books available for your reference.
The following Sun Cluster books support the Sun Cluster 3.1, 2004, and 2005 releases. If you are maintaining a different version of Sun Cluster software, refer to the appropriate documentation. All Sun Cluster documentation is available at http://docs.sun.com.
Documentation that is not available at http://docs.sun.com is listed with the appropriate URL.
Table P–2 Hardware Documentation
Title |
Part Number |
Sun StorEdge Traffic Manager Installation and Configuration Guide |
817-3674 |
Table P–3 Sun Cluster Documentation
Application |
Title |
Concepts | |
Overview | |
Hardware administration |
Sun Cluster 3.0-3.1 Hardware Administration Manual for Solaris OS Individual hardware administration guides |
Software installation | |
Data service administration |
Sun Cluster Data Services Planning and Administration Guide for Solaris OS Individual data service guides |
Data service development | |
System administration | |
Error messages | |
Command and function reference | |
Release Notes |
This document contains information about commands that are used to install, configure, or upgrade a Sun Cluster configuration. This document might not contain complete information about basic UNIX® commands and procedures such as shutting down the system, booting the system, and configuring devices.
See one or more of the following sources for this information:
Online documentation for the SolarisTM Operating System (Solaris OS)
Other software documentation that you received with your system
Solaris Operating System man pages
If you have problems installing or using Sun Cluster, contact your service provider and provide the following information.
Your name and email address (if available)
Your company name, address, and phone number
The model number and serial number of your systems
The release number of the operating environment (for example, Solaris 9)
The release number of Sun Cluster (for example, Sun Cluster 3.1 8/05)
Use the following commands to gather information about your system for your service provider.
Command |
Function |
prtconf -v |
Displays the size of the system memory and reports information about peripheral devices |
psrinfo -v |
Displays information about processors |
showrev -p |
Reports which patches are installed |
prtdiag -v |
Displays system diagnostic information |
/usr/cluster/bin/scinstall -pv |
Displays Sun Cluster release and package version information |
Also have available the contents of the /var/adm/messages file.
The docs.sun.comSM Web site enables you to access Sun technical documentation online. You can browse the docs.sun.com archive or search for a specific book title or subject. The URL is http://docs.sun.com.
Sun Microsystems offers select product documentation in print. For a list of documents and how to order them, see “Buy printed documentation” at http://docs.sun.com.
The following table describes the typographic changes that are used in this book.
Table P–4 Typographic Conventions
Typeface or Symbol |
Meaning |
Example |
AaBbCc123 |
The names of commands, files, and directories, and onscreen computer output |
Edit your .login file. Use ls -a to list all files. machine_name% you have mail. |
AaBbCc123 |
What you type, contrasted with onscreen computer output |
machine_name% su Password: |
AaBbCc123 |
Command-line placeholder: replace with a real name or value |
The command to remove a file is rm filename. |
AaBbCc123 |
Book titles, new terms, and terms to be emphasized |
Read Chapter 6 in the User's Guide. Perform a patch analysis. Do not save the file. [Note that some emphasized items appear bold online.] |
The following table shows the default system prompt and superuser prompt for the C shell, Bourne shell, and Korn shell.
Table P–5 Shell Prompts
Shell |
Prompt |
C shell prompt |
machine_name% |
C shell superuser prompt |
machine_name# |
Bourne shell and Korn shell prompt |
Bourne shell and Korn shell superuser prompt |
Sun Microsystems offers training in many Sun technologies through a variety of instructor-led courses and self-paced courses. For information about the training courses that Sun offers and to enroll in a class, visit Sun Training at http://training.sun.com/.
