The following table summarizes the tasks for installing and configuring Sun Cluster HA for SWIFTAlliance Gateway and provides cross-references to detailed instructions for performing these tasks. Perform the tasks in the order that they are listed in the table.
Table 1–2 Tasks for Installing and Configuring Sun Cluster HA for SWIFTAlliance Gateway|
Task |
Instructions |
Plan the SWIFTAlliance Gateway installation |
Planning the Sun Cluster HA for SWIFTAlliance Gateway Installation and Configuration |
Install and configure SWIFTAlliance Gateway | |
Install the Sun Cluster HA for SWIFTAlliance Gateway packages | |
Register the Sun Cluster HA for SWIFTAlliance Gateway data service and configure the cluster for the data service |
Registering and Configuring the Sun Cluster HA for SWIFTAlliance Gateway |
Verify Sun Cluster HA for SWIFTAlliance Gateway |
Verifying the Sun Cluster HA for SWIFTAlliance Gateway Installation and Configuration |
Tune the Sun Cluster HA for SWIFTAlliance Gateway fault monitor |
Tuning the Sun Cluster HA for SWIFTAlliance Gateway Fault Monitor |
(Optional) Debug Sun Cluster HA for SWIFTAlliance Gateway |
