The relationship between a resource type version and the release of Sun Cluster is shown in the following table. The release of Sun Cluster indicates the release in which the version of the resource type was introduced.
Resource Type Version |
Sun Cluster Release |
1.0 |
3.0 5/02 |
2 |
3.1 9/04 |
To determine the version of the resource type that is registered, use one command from the following list:
scrgadm -p
scrgadm -pv
The resource type registration (RTR) file for this resource type is /usr/cluster/lib/rgm/rtreg/SUNW.HAStoragePlus.
