The relationship between the version of each preregistered resource type and the release of Sun Cluster is shown in the following table. The release of Sun Cluster indicates the release in which the version of the resource type was introduced.
Resource Type |
Resource Type Version |
Sun Cluster Release |
SUNW.LogicalHostname
1.0 |
3.0 |
2 |
3.1 9/04 |
SUNW.SharedAddress
1.0 |
3.0 |
2 |
3.1 9/04 |
To determine the version of the resource type that is registered, use one command from the following list:
scrgadm -p
scrgadm -pv
This example shows the command for registering version 2 of the SUNW.LogicalHostname resource type during an upgrade.
# scrgadm -a -t SUNW.LogicalHostname:2 |
