Sun Cluster Data Services Planning and Administration Guide for Solaris OS
Resource Property Attributes
The following information describes the resource property attributes that can be used to change system-defined properties or create extension properties.
Caution – Caution –
You cannot specify Null or the empty string (“”) as the default value for boolean, enum, or int types.
Property names are shown first, followed by a description.
Array_maxsize
For stringarray type, the maximum number of array elements permitted.
Array_minsize
For stringarray type, the minimum number of array elements permitted.
Default
Indicates a default value for the property.
Description
A string annotation that is intended to be a brief description of the property. The Description attribute cannot be set in the RTR file for system-defined properties.
Enumlist
For an enum type, a set of string values that are permitted for the property.
Extension
If used, indicates that the RTR file entry declares an extension property that is defined by the resource type implementation. Otherwise, the entry is a system-defined property.
Max
For an int type, the maximum value permitted for the property.
Maxlength
For string and stringarray types, the maximum string length permitted.
Min
For an int type, the minimal value permitted for the property.
Minlength
For string and stringarray types, the minimum string length permitted.
Property
The name of the resource property.
Tunable
Indicates when the cluster administrator can set the value of this property in a resource. Can be set to NONE or FALSE to prevent the administrator from setting the property. Values that allow administrator tuning are TRUE or ANYTIME (at any time), AT_CREATION (only when the resource is created), or WHEN_DISABLED (when the resource is offline). To establish other tunability conditions, such as “when monitoring is disabled” or “when offline”, set this attribute to ANYTIME and validate the state of the resource in the Validate method.
The default differs for each standard resource property, as shown in the following section. The default setting for tuning an extension property, if not otherwise specified in the RTR file, is TRUE (ANYTIME).
Type of the property
Allowable types are: string, boolean, int, enum, and stringarray. You cannot set the type attribute in an RTR file entry for system-defined properties. The type determines acceptable property values and the type-specific attributes that are allowed in the RTR file entry. An enum type is a set of string values.
