This example describes how to configure an RGOffload resource (rgofl), the critical resource group that contains the RGOffload resource (oracle_rg), and scalable resource groups that are offloaded when the critical resource group comes online (IWS-SC, IWS-SC-2). The critical resource in this example is oracle-server-rs.
In this example, oracle_rg, IWS-SC, and IWS-SC-2 can be mastered on any node of cluster “triped”, phys-triped-1, phys-triped-2, phys-triped-3.
[Determine whether the SUNW.RGOffload resource type is registered.] # scrgadm -p|egrep SUNW.RGOffload [If needed, register the resource type.] # scrgadm -a -t SUNW.RGOffload [Set the Desired_primaries to zero in each resource group to be offloaded by the RGOffload resource.] # scrgadm -c -g IWS-SC-2 -y Desired_primaries=0 # scrgadm -c -g IWS-SC -y Desired_primaries=0 [Add the RGOffload resource to the critical resource group and set the extension properties.] # scrgadm -aj rgofl -t SUNW.RGOffload -g oracle_rg \ -x rg_to_offload=IWS-SC,IWS-SC-2 -x continue_to_offload=TRUE \ -x max_offload_retry=15 [Enable the RGOffload resource.] # scswitch -ej rgofl [Set the dependency of the critical failover resource to the RGOffload resource.] # scrgadm -c -j oracle-server-rs -y Resource_dependencies=rgofl [Bring the resource groups to be offloaded online on all nodes.] # scswitch -z -g IWS-SC,IWS-SC-2 -h phys-triped-1,phys-triped-2,phys-triped-3 [If the critical failover resource group is not online, bring it online.] # scswitch -Z -g oracle_rg |
