Before you start to install and configure the Sun Java System Application Server EE (HADB), use this section in conjunction with the worksheets in “Configuration Worksheets” in Sun Cluster Data Services Planning and Administration Guide for Solaris OS.
Store static files and data on the local file system of each cluster node. The Sun Java System Application Server EE (HADB) software is installed when you install the Sun Java System Application Server Enterprise Edition software. See Sun Cluster Data Service for Sun Java System Application Server Guide for Solaris OS documentation for instructions. When the database is created, the configuration and data files are created by default on the local file system of each cluster node. For details, see the Sun Java System Application Server documentation.
