This part contains the following appendixes:
Appendix A, Deploying DSCC WAR File With Supported Application Servers
Appendix B, Working With Sun Cryptographic Framework on Solaris 10 Systems
To access and manage the server instances using web-based interface, you must deploy the WAR file, supplied with the Directory Server Enterprise Edition software, with any of the supported application servers.
All the supported application servers must comply to the following requirements:
All Java permissions should be granted to the DSCC application.
By default, all the supported application servers except Sun Java System Application Server grant such permissions to the DSCC application.
The tag pooling feature of your application server should be disabled.
By default, this feature is disabled in all the supported application servers except Tomcat.
For more information about the list of supported application servers, refer to Supported Application Servers for Directory Service Control Center in Sun Directory Server Enterprise Edition 7.0 Release Notes.
The following procedures help you in deploying your war file with an application server. These procedures do not intend to cover all the methods to deploy the war file in your application server. Refer to the respective application server documentation for more information.
The http port numbers, used to connect to the console, mentioned in the following sections are the default port numbers for each application server. The port numbers may differ if the default port numbers are already in use.
After you install Directory Server Enterprise Edition, you can deploy the WAR file to access DSCC. The following procedure contains the deployment instructions to deploy the WAR file:
Create the WAR file for DSCC.
$ install-path/bin/dsccsetup war-file-create |
For native packages installation, the WAR file is created in the /var/opt/SUNWdsee7/ directory.
For zip distribution installation, the WAR file is created in the install-path/var directory.
Initialize the DSCC registry.
$ install-path/bin/dsccsetup ads-create Choose password for Directory Service Manager: Confirm password for Directory Service Manager: Creating DSCC registry... DSCC Registry has been created successfully |
To create server instances on the same host where DSCC is deployed, register the DSCC agent in Common Agent Container.
$install-path/bin/dsccsetup cacao-reg |
Type the following command to check the location and other statistics of your WAR file and DSCC registry:
$ install-path/bin/dsccsetup status |
Create an application server instance.
$ mkdir /local/domainroot $ cd app-server-install-path/bin $ asadmin create-domain --domaindir /local/domainroot --adminport 3737 \ --user admin dscc7 |
Edit the server.policy file.
Open the server.policy file.
$ vi /local/domainroot/dscc7/config/server.policy |
Add the following statements to the end of the file:
// Permissions for Directory Service Control Center
grant codeBase "file:${com.sun.aas.instanceRoot}/applications/j2ee-modules/dscc7/-"
permission java.security.AllPermission;
The addition configures the application server to grant all the Java permissions to the DSCC application.
Deploy the WAR file in your application server instance.
$ asadmin start-domain --domaindir /local/domainroot --user admin dscc7 $ cp install-path/var/dscc7.war /local/domainroot/dscc7/autodeploy |
For more information about creating and configuring application server instances and deploying the WAR file, refer to the Sun Java System Application Server Online Help.
Open DSCC.
Use http://hostname:8080/dscc7 or https://hostname:8181/dscc7 based on the configuration of your application server.
The Directory Service Manager Login page displays.
After you install Directory Server Enterprise Edition, you can deploy the WAR file to access DSCC. Refer to the following procedure for deployment instructions:
The following example shows how to install DSCC in Tomcat on a Solaris 10 system.
Type the following command to check the location and other statistics of your war file and DSCC registry:
Install Tomcat and create an instance.
Identify your Tomcat installation and instance.
$ export CATALINA_HOME=tomcat-install-path $ export CATALINA_BASE=tomcat-instance-path $ export JAVA_HOME=jdk-home-dir |
For installing Tomcat and creating instances, refer to the Tomcat documentation.
Enable replication topology rendering.
${CATALINA_HOME}/bin/shutdown.sh
export CATALINA_OPTS="-Djava.awt.headless=true"
${CATALINA_HOME}/bin/startup.sh
Deploy the WAR file.
$ mkdir ${CATALINA_BASE}/webapps/dscc7
$ unzip -d ${CATALINA_BASE}/webapps/dscc7 install-path/var/dscc7.war
You must disable the tag pooling on your Tomcat server instance by setting the enablePooling parameter value to false in ${CATALINA_BASE}/conf/web.xml. Add the following code in the web.xml file:
<init-param>
<param-name>enablePooling</param-name>
<param-value>false</param-value>
</init-param>
Verify the permissions of startup.sh for Solaris operating system (tomcat5.exe or tomcat6.exe on Windows) and type the following command:
$ ${CATALINA_HOME}/bin/startup.sh
Use http://hostname:8080/dscc7 to connect to DSCC.
The following example shows how to install DSCC in BEA WebLogic Server on a Solaris 10 system.
Browse the WebLogic console using http://localhost:7001/console.
Goto base_domain/Deployments.
Click Lock and Edit.
Click Install.
Click Upload your file(s).
In Deployment Archive, select install-path/var/dscc7.war.
Click Next.
Select dscc7.war and click Next a few times and Finish.
Click Activate Changes in the top left corner.
The dscc7 deployment must be in the active state.
The above steps are an example of how dscc7.war file is deployed into BEA WebLogic Server. The BEA WebLogic Server documentation is the only trustable source of information for deploying WAR files.
Use http://hostname:port/dscc7 to connect to DSCC.
The default port number for BEA WebLogic Server is 7001.
The following example shows how to install DSCC in Sun Java System Web Server on a Solaris 10 system.
If you install Sun Java System Web Server as root, web server daemons run as a webservd user. In that case, the easiest way to make your deployment work successfully is to install Directory Server Enterprise Edition and pre-configure DSCC as a webservd user.
Deploy the war file.
Browse the Sun Java System Web Server console using https://hostname:8989.
Under the Common Tasks tab, click Add Web Application in the Virtual Server Tasks section.
In the Add Web Application form, provide the following values and click OK.
Web Application Location: install-path/var/dscc7.var
URI: /dscc7
Enable server-side HTML
Click the Content Handling tab of the virtual server.
In the Parsed HTML/SSI section, click New and then OK.
In the main window, click Deployment Pending link located in the top right corner and complete deployment by following the wizard.
Edit the magnus.conf file of the virtual server:
# vi web-server-install-path/admin-server/config/magnus.conf |
Add the following line:
type=magnus-internal/parsed-html exts=shtml |
Under the Configurations tab, click the Refresh button.
Click Instance Configuration Modified in the top right corner and click Pull and deploy configuration from virtual-server and click OK.
For the detailed information about enabling server-side HTML, see Enabling Server-side HTML in Sun Java System Web Server 7.0 Developer’s Guide.
Under the Configurations tab, select the configuration that you have created and click Start.
This appendix briefly explains how to use the Sun Crypto Accelerator cards through the Sun cryptographic framework on Solaris 10 systems with Directory Server and Directory Proxy Server. For more information about the framework, see the respective documentation.
Using Directory Server With Cryptographic Hardware on a Solaris 10 System
Using Directory Proxy Server With Cryptographic Hardware on a Solaris 10 System
This procedure is designed for use with Sun Crypto Accelerator hardware. Perform the following procedure as the same user who runs the Directory Server instance.
Set the PIN used to access the cryptographic framework by typing the pktool setpin command.
Set the PIN as the same user as the one running Directory Server.
Export the current Directory Server certificate to a PKCS#12 file.
The following command shows how to perform this step if the Directory Server instance is located under /local/ds/.
$ dsadm export-cert -o cert-file /local/ds defaultCert |
Configure Directory Server to use the appropriate token when accessing the key material.
Typically, the token is Sun Metaslot.
$ dsconf set-server-prop 'ssl-rsa-security-device:Sun Metaslot' |
Stop Directory Server.
$ dsadm stop /local/ds |
(Optional) If you have no other certificates in the existing certificate database for the Directory Server instance, remove the certificate database.
$ rm -f /local/ds/alias/*.db |
This optional step ensures that no certificates are stored in the software database.
Create a new certificate database backed by the Solaris cryptographic framework.
If you have not removed the certificate database, you do not need to run the modutil -create line in this example.
$ /usr/sfw/bin/64/modutil -create -dbdir /local/ds/alias -dbprefix slapd- $ /usr/sfw/bin/64/modutil -add "Solaris Kernel Crypto Driver" -libfile \ /usr/lib/64/libpkcs11.so -dbdir /local/ds/alias -dbprefix slapd- $ /usr/sfw/bin/64/modutil -enable "Solaris Kernel Crypto Driver" \ -dbdir /local/ds/alias -dbprefix slapd- |
Import the PKCS#12 certificate that you exported.
$ /usr/sfw/bin/64/pk12util -i cert-file \ -d /local/ds/alias -P slapd- -h "Sun Metaslot" $ /usr/sfw/bin/64/certutil -M -n "Sun Metaslot:defaultCert" -t CTu \ -d /local/ds/alias -P slapd- |
If your accelerator board has a FIPS 140-2 keystore, for added security, make sure that the private key is stored on the device. Sun Crypto Accelerator 4000 and 6000 boards have FIPS 140-2 keystores, for example. The exact process depends on the board.
Make sure that the cryptographic hardware supports the cipher suites that you want to use. Not all the hardwares support all cipher suites. As a workaround, you can use dsconf ssl-cipher-family to set specific suites.
Create a password file that contains the PIN needed to access the cryptographic framework.
This file is required only when the password is changed in step 1.
$ echo "Sun Metaslot:password" > /local/dsInst/alias/slapd-pin.txt |
If the password has been changed in step 1, password is the new password, otherwise it is the one currently in use.
Start Directory Server.
$ dsadm start /local/ds |
This procedure is designed for use with Sun Crypto Accelerator hardware. Perform the following procedure as the same user who runs the Directory Proxy Server instance.
Stop Directory Proxy Server.
$ dpadm stop /local/dps |
Turn off the certificate database password storage.
$ dpadm set-flags /local/dps cert-pwd-prompt=on Choose the certificate database password: Confirm the certificate database password: |
Use the same password that you typedwhen turning off the certificate database password storage.
Generate a key pair by using the cryptographic framework as the key store.
$ keytool -genkeypair -alias defaultDPScert -dname "ou=dps server,dc=example,dc=com" -keyalg RSA -sigalg MD5withRSA -validity 3652 -storetype PKCS11 -keystore NONE -storepass pin-password |
pin-password is the password that you set as the PIN with the pktool setpin command.
Edit the Directory Proxy Server configuration file, adding the following attributes to the base entry, cn=config.
serverCertificateNickName: defaultDPScert certificateKeyStore: NONE certificateKeyStoreType: PKCS11
Start Directory Proxy Server.
$ dpadm start /local/dps |
