Sun Directory Server Enterprise Edition 7.0 Reference
Chapter 1 Directory Server Enterprise Edition File Reference
This chapter describes the files found after you install Directory Server Enterprise Edition, and after you create server instances.
The examples shown in this chapter are for Solaris systems. File extensions and path separators may differ for your operating system. This chapter includes the following sections.
If you installed software from native packages, you may also use the packaging commands on your system to list the files installed. For example, after installing from native packages on Solaris systems, you can obtain a full list for a particular package using the pkgchk -v package-name command.
Software Layout for Directory Server Enterprise Edition
This section describes the file layout you find after installing Directory Server Enterprise Edition from the zip distribution. All files locations are relative to the path where you installed the product. For information on default native package installation locations, see Default Paths and Command Locations.
install-path/bin/
The directory houses the following files of interest.
install-path/bin/cacaoadm
Command to administer the Common Agent Container.
install-path/bin/certutil
NSS certificate manipulation command used by other tools, not intended to be used directly.
install-path/bin/dpadm
Directory Proxy Server command for local administration. See dpadm(1M).
install-path/bin/dpconf
Directory Proxy Server command for configuration over LDAP. See dpconf(1M).
install-path/bin/dsadm
Directory Server command for local administration. See dsadm(1M).
install-path/bin/dsccmon
Command to monitor servers managed through Directory Service Control Center. See dsccmon(1M).
install-path/bin/dsccreg
Command to manage the Directory Service Control Center registry. See dsccreg(1M).
install-path/bin/dsccsetup
Command to set up Directory Service Control Center. See dsccsetup(1M).
install-path/bin/dsconf
Directory Server command for configuration over LDAP. See dsconf(1M).
install-path/bin/dsmig
Directory Server command for migration from version 5.2 to this version of Directory Server. See dsmig(1M).
install-path/bin/dsutil
Directory Server command for activating or inactivating a user or users member of a role. See dsutil(1M).
install-path/bin/entrycmp
Directory Server command for comparing directory entries across replica. See entrycmp(1).
install-path/bin/fildif
Directory Server command for filtering LDIF content. See fildif(1).
install-path/bin/insync
Directory Server command for examining replica synchronization. See insync(1).
install-path/bin/ldif
Directory Server command for formatting input by adding base64 encoding to make it suitable for inclusion in an LDIF file. See ldif(1)
install-path/bin/mmldif
Directory Server command for combining LDIF content. See mmldif(1).
install-path/bin/pwdhash
Directory Server command for displaying the hashed form of a password value. See pwdhash(1).
install-path/bin/repldisc
Directory Server command for discovering a replication topology. See repldisc(1).
install-path/bin/support_tools
Directory that contains Directory Server commands, not intended for use without help of a qualified support personnel.
install-path/dsrk/bin/authrate
Directory Server Resource Kit command to measure authentication rate. See authrate(1).
install-path/dsrk/bin/dsmlmodify
Directory Server Resource Kit command to add, modify, rename, move, or delete directory entries through Directory Services Markup Language (DSML) v2. See dsmlmodify(1).
install-path/dsrk/bin/dsmlsearch
Directory Server Resource Kit command to find directory entries through Directory Services Markup Language (DSML) v2. See dsmlsearch(1).
install-path/dsrk/bin/ldapcmp
Directory Server Resource Kit command to compare LDAP entries from two directories. See ldapcmp(1).
install-path/dsrk/bin/ldapcompare
Directory Server Resource Kit command to perform LDAP compare operations. See ldapcompare(1).
install-path/dsrk/bin/ldapdelete
Directory Server Resource Kit command to delete directory entries. See ldapdelete(1).
install-path/dsrk/bin/ldapmodify
Directory Server Resource Kit command to update entries over LDAP. See ldapmodify(1).
install-path/dsrk/bin/ldappasswd
Directory Server Resource Kit command to change user passwords. See ldappasswd(1).
install-path/dsrk/bin/ldapsearch
Directory Server Resource Kit command to search a directory. See ldapsearch(1).
install-path/dsrk/bin/ldapsubtdel
Directory Server Resource Kit command to recursively delete a directory subtree. See ldapsubtdel(1).
install-path/dsrk/bin/ldifxform
Directory Server Resource Kit command to reformat LDIF content. See ldifxform(1).
install-path/dsrk/bin/logconv
Directory Server Resource Kit command to analyze Directory Server access logs. See logconv(1).
install-path/dsrk/bin/makeldif
Directory Server Resource Kit command to generate LDIF content for testing and benchmarking purposes. See makeldif(1).
install-path/dsrk/bin/modrate
Directory Server Resource Kit command to measure modification performance for an LDAP directory. See modrate(1).
install-path/dsrk/bin/searchrate
Directory Server Resource Kit command to measure search performance for an LDAP directory. See searchrate(1).
install-path/dsrk/lib/
Libraries used by Directory Server Resource Kit commands, not intended to be used directly.
install-path/etc/
Directory Server Enterprise Edition agent configuration information, not intended to be used directly.
install-path/examples/
Sample Directory Server plug-ins.
install-path/ext/cacao_2/
Common agent container files shared by Directory Server Enterprise Edition component products, not intended to be used directly.
install-path/ext/SUNWmfwk/
Java ES Monitoring Framework files used by Directory Server, not intended to be used directly.
install-path/include/
Directory Server plug-in header files.
install-path/jre/
Java Runtime Environment, not intended to be used directly.
install-path/legal/
Legal files.
install-path/lib/
Libraries shared by Directory Server Enterprise Edition component products, not intended to be used directly.
install-path/resources/dcc7app
DSCC files.
install-path/resources/dpadm
Localized resource files used by dpadm.
install-path/resources/dsadmin
Localized resource files used by dsadmin
install-path/resources/install/
Directory Server instance installation templates, not intended to be used directly.
install-path/resources/ldif/Example.ldif
Sample Directory Server LDIF content.
install-path/resources/ldif/Example-roles.ldif
Sample Directory Server LDIF content with grouping based on roles.
install-path/man/
Directory Server Enterprise Edition online reference manual pages. See also Sun Directory Server Enterprise Edition 7.0 Man Page Reference.
install-path/resources/plugins/
Directory Server plug-in configuration files, not intended to be used directly.
install-path/resources/schema/
Directory Server instance LDAP schema templates, not intended to be used directly.
install-path/var/
Container for runtime files, not intended to be used directly.
Directory Server Instance Default Layout
This section describes the file layout you find after creating a Directory Server instance. The instance-path is the file system path where you created the instance.
instance-path/alias/
NSS certificate database directory.
instance-path/alias/certmap.conf
NSS certificate mapping configuration file.
instance-path/bak/
Default data backup directory.
Each directory database backup is held in its own file system directory. The name of the backup directory corresponds to the time and date of the backup.
instance-path/config/
Server configuration directory.
instance-path/config/dse.ldif
Server configuration file, not intended to be edited directly.
instance-path/config/schema/
LDAP schema configuration files. See dirserv(5dssd).
instance-path/db/
Default server database files directory. When a suffix has been created, the following database files are stored in this file system directory.
__db.00x
Files used internally by the database. Do not move, delete, or modify these files.
DBVERSION
File that identifies the version of the database.
guardian
File used to store information about the state of the database, used to determine whether database recovery is required.
log.xxxxxxxxxx
Files used to store the database transaction logs.
suffix
Files that store your directory suffix information. The directory name is derived from the suffix name, such that the database for a suffix identified by DN dc=example,dc=com is stored in a file system directory named example.
For every index defined in the database, the suffix directory contains a file with a name of the form suffix_indexedAttr.db3, such that an index of CNs for dc=example,dc=com has file name example_cn.db3.
Suffix directories also contain a file named suffix_id2entry.db3. The suffix_id2entry.db3 file contains the directory database entries.
If necessary, all index files can be rebuild from the suffix_id2entry.db3 file. To recreate the index files, reindex the suffix.
instance-path/locks/
Lock files directory.
Lock files stored here in subdirectories exports/, imports/, and server/ prevent simultaneous operations from conflicting with each other. The lock mechanisms allow one server instance to run at a time. The lock mechanisms also permit only one dsadm import (offline import) operation at a time. As a result, no export or server instance operations can be run during import.
The lock restriction does not however apply to dsconf import (online import) operations. Multiple online imports can run at the same time.
instance-path/logs/
Default server logs directory. The following files are stored here.
access logs
This file records information about client access to Directory Server. For detail about access logs, see Access Logs.
audit logs
This file records information about modifications to Directory Server data. For detail about audit logs, see Audit Logs.
core files
By default, server core files are dumped here during a crash.
errors logs
This file records errors, warnings, and informational messages logged during Directory Server operation. For detail about errors logs, see Error Logs.
pid file
This file holds the process identifier of the running server.
instance-path/plugins/DSMLv2.xsd
DSMLv2 schema file.
instance-path/plugins/soap-env.xsd
SOAP schema location for DSMLv2.
instance-path/plugins/words-english-bug.txt
Default dictionary file used for strong password checks.
instance-path/plugins/signatures/
Plug-in signatures directory, not intended to be used directly.
instance-path/tmp/
Server runtime files directory, not intended to be used directly.
Directory Proxy Server Instance Default Layout
This section describes the file layout you find after creating a Directory Proxy Server instance. The instance-path is the file system path where you created the instance.
Certificate database files, not intended to be used directly.
Server configuration files, not intended to be used directly.
instance-path/etc/
Additional instance configuration, not intended to be used directly.
instance-path/logs/
access logs
This file records information about the requests processed by Directory Proxy Server. For detail about access logs, see Access Logs for Directory Proxy Server.
errors logs
This file records errors, warnings, and informational messages logged during Directory Proxy Server operation. For detail about errors logs, see Error Logs for Directory Proxy Server.
instance-path/tmp/
