Name | Description | SYNTAX VALUES | Attributes | See Also
Prioritized replication lets you force a Directory Server supplier to assign higher priority to certain updates replicated on a Directory Server consumer. You prioritize replication operations by creating replication priority rules.
Syntax |
ATTR_NAME |
Default Value |
None |
Is readable |
Yes |
Is modifiable |
Yes |
Is multi-valued |
No |
This property specifies the attribute type to which the replication priority rule applies.
Syntax |
DN |
Default Value |
None |
Is readable |
Yes |
Is modifiable |
Yes |
Is multi-valued |
No |
This property specifies the DN under which the replication priority rule applies. For example, if you set base-dn:ou=administrators,dc=example,dc=com, then changes to uid=myAdmin,ou=administrators,dc=example,dc=com might be replicated with high priority, but changes to uid=bjensen,ou=people,dc=example,dc=com would not.
Syntax |
DN |
Default Value |
None |
Is readable |
Yes |
Is modifiable |
Yes |
Is multi-valued |
No |
This property specifies a bind DN for an account whose updates might be replicated with high priority.
Syntax values shown in lower case or partly in lower case are literal values.
Those shown in upper case are syntax types, defined as follows:
A valid attribute type name such as cn or objectClass.
true or false.
A valid distinguished name such as ou=People,dc=example,dc=com.
A duration specified in months (M), weeks (w), days (d), hours (h), minutes (m), seconds (s), and miliseconds (ms), or some combination with multiple specifiers. For example, you can specify one week as 1w, 7d, 168h, 10080m, or 604800s. You can also specify one week as 1w0d0h0m0s.
DURATION properties typically do not each support all duration specifiers (Mwdhms). Examine the output of dsconf help-properties for the property to determine which duration specifiers are supported.
A valid e-mail address.
An IP address or host name.
A positive integer value between 0 and the maximum supported integer value in the system address space. On 32-bit systems, 2147483647. On 64-bit systems, 9223372036854775807.
An interval value of the form hhmm-hhmm 0123456, where the first element specifies the starting hour, the next element the finishing hour in 24-hour time format, from 0000-2359, and the second specifies days, starting with Sunday (0) to Saturday (6).
An IP address or range of address in one of the following formats:
IP address in dotted decimal form.
IP address and bits, in the form of network number/mask bits.
IP address and quad, in the form of a pair of dotted decimal quads.
All address. A catch-all for clients that are note placed into other, higher priority groups.
0.0.0.0. This address is for groups to which initial membership is not considered. For example, for groups that clients switch to after their initial bind.
IP address of the local host.
A valid LDAP URL as specified by RFC 2255.
A memory size specified in gigabytes (G), megabytes (M),kilobytes (k), or bytes (b). Unlike DURATION properties, MEMORY_SIZE properties cannot combine multiple specifiers. However, MEMORY_SIZE properties allow decimal values, for example, 1.5M.
A valid cn (common name).
A three-digit, octal file permissions specifier. The first digit specifies permissions for the server user ID, the second for the server group ID, the last for other users. Each digit consists of a bitmask defining read (4), write (2), execute (1), or no access (0) permissions, thus 640 specifies read-write access for the server user, read-only access for other users of the server group, and no access for other users.
The full path to the file from which the bind password should be read.
A valid, absolute file system path.
A DirectoryString value, as specified by RFC 2252.
An SSL cipher supported by the server. See the Reference for a list of supported ciphers.
An SSL protocol supported by the server. See the Reference for a list of supported protocols.
A time of the form hhmm in 24-hour format, where hh stands for hours and mm stands for minutes.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Availability |
SUNWdsee7 |
Stability Level |
Evolving |
