Name | Description | Attributes | See Also
Syntax |
dn |
Default value |
Must be set |
No |
Is modifiable |
Yes |
Is multivalued |
No |
Requires restart |
No |
This property specifies the DN of a target entry in a search operation. The availability monitor uses the search operation to test a connection to the data source.
This property takes a Distinguished Name (DN) value.
This property is used to configure the following features:
The common name of the LDAP data source
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Availability |
SUNWdsee7 |
Stability Level |
Evolving |
dpconf(1M)
