Name | Description | Attributes | See Also
Syntax |
duration |
Default value |
5000 |
Must be set |
No |
Is modifiable |
Yes |
Is multivalued |
No |
Requires restart |
No |
This property specifies the maximum length of time that the availability monitor tries to retrieve the target entry in a search operation. The availability monitor uses the search operation to test a connection to the data source.
The duration is expressed in milliseconds.
The value of this property must be at least 1.
This property is used to configure the following features:
The common name of the LDAP data source
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Availability |
SUNWdsee7 |
Stability Level |
Evolving |
dpconf(1M)
