Name | Description | Attributes | See Also
Syntax |
enumeration |
Default value |
proactive |
Must be set |
No |
Is modifiable |
Yes |
Is multivalued |
No |
Requires restart |
No |
This property specifies the monitoring mode of a data source.
This property can take the following values in addition to the default.
The availability monitor checks the availability of the data source continuously.
The availability monitor checks the availability of the data source only after a client request times out, or when an I/O error has been detected.
This property is used to configure the following features:
A JDBC data source is defined for each relational database to which you want LDAP clients to have access. Currently, only one JDBC data source is supported per JDBC data view.
The common name of the LDAP data source
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Availability |
SUNWdsee7 |
Stability Level |
Evolving |
dpconf(1M)
