Name | Description | Attributes | See Also
Syntax |
integer |
Default value |
5 |
Must be set |
No |
Is modifiable |
Yes |
Is multivalued |
No |
Requires restart |
No |
This property specifies the number of new connections that are created when the server needs more connections for operations.
This property takes an integer.
The value of this property must be at least 1.
This property is used to configure the following features:
A JDBC data source is defined for each relational database to which you want LDAP clients to have access. Currently, only one JDBC data source is supported per JDBC data view.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Availability |
SUNWdsee7 |
Stability Level |
Evolving |
dpconf(1M)
