If you are using Solaris 2.5.1 or 2.6 operating environment and you have installed the JDK in any location other than the default location (/usr/java1.2), JNI native applications might have problems locating the JDK shared libraries. You can work around this problem by setting the environment variable LD_LIBRARY_PATH to include the jre/lib/sparc or jre/lib/i386 directory of the JDK installation. This problem does not exist on either Solaris 7 software or Solaris 8 software.
