To ensure that context-sensitive help within a help dialog operates correctly, you must provide the following entry points (IDs) within your help on help volume. (These are already included in the Help4Help source files.)
ID |
Fopic Description |
Displays an introduction to using the help system. This topic is displayed when you choose Using Help from the general help dialog's Help menu, or when you press F1 in a quick help dialog. (The ID _hometopic is created automatically by the <hometopic> element.) |
Displays the copyright and version information for the help on help volume. This topic is displayed when you choose Version from the general help dialog's Help menu. (The ID _copyright is created automatically by the <copyright> element.) |
Displays a topic that describes how to use the History dialog. This topic is displayed when you choose Help or press F1 within the History dialog. |
Displays a topic describing how to use the Print dialog. This topic is displayed when you choose Help or press F1 within the Print dialog. |
Displays a topic describing how to use the Index Search dialog. This topic is displayed when you choose Help or press F1 within the Index Search dialog. |
Displays a topic describing how to use the Search Volume Selection Dialog. This topic is displayed when you choose Help or press F1 within the Search Volume Selection Dialog. |
