To remove rights for an object or entry use:
For object
| nischmod class-right object-name |
For entry
| nischmod class-right [column-name=value],table-name |
For example, to remove create and destroy rights from the group of the sales.doc.com. directory object you would type:
| client% nischmod g-cd sales.doc.com. |
For example to remove destroy rights from group for the name=abe entry in the hosts.org_dir.doc.com. table, you would type:
| client% nischmod g-d '[name=abe],hosts.org_dir.doc.com.' |
