As discussed in a previous section, you can continue to use SunOS release 4.x print commands if you have the SunOS/BSD Source Compatibility Package. Table 11-1 shows the basic user print command equivalents.
Table 11-1 User Print Command Equivalents|
SunOS release 4.x |
SunOS release 5.6 |
Function |
Print a file to the default printer |
lpr -P printer filename |
lp -d printer file |
Print a file to a specific printer |
Look at a list of the files waiting to print on the default printer |
lpstat -d |
Determine which is the default printer |
Check /etc/printcap
lpstat -a |
Determine which printers are available |
Cancel a print job on the default printer |
