The socket() call creates a socket in the specified domain and of the specified type.
s = socket(domain, type, protocol); |
If the protocol is unspecified (a value of 0), the system selects a protocol that supports the requested socket type. The socket handle (a file descriptor) is returned.
The domain is specified by one of the constants defined in sys/socket.h. Constants named AF_
suite specify the address format to use in interpreting names as shown in Table 2-1.
Apple Computer Inc. Appletalk network |
Internet domain |
Xerox Corporation PUP internet |
Unix file system |
Socket types are defined in sys/socket.h. These types--SOCK_STREAM, SOCK_DGRAM, or SOCK_RAW--are supported by AF_INET
and AF_UNIX
. The following creates a stream socket in the Internet domain:
s = socket(AF_INET, SOCK_STREAM, 0); |
This call results in a stream socket with the TCP protocol providing the underlying communication. The following creates a datagram socket for intramachine use:
s = socket(AF_UNIX, SOCK_DGRAM, 0); |
Use the default protocol (the protocol argument is 0) in most situations. You can specify a protocol other than the default, as described in "Advanced Topics".
