Solaris User's Guide
Fwd (Fast Forward) Button
This button controls the forward movement of the play position pointer. Click SELECT on the Fwd button to move the play position pointer forward.
If there is no selection in the canvas, clicking SELECT on the Fwd button causes the pointer to jump forward, segment by segment, until it reaches the end of the file.
If there is a selection, the pointer's movement is constrained to the selection.
Hold down SELECT on the Fwd button to play the selection at an accelerated speed until you release SELECT or until the play position pointer reaches the end of the selection.
