The MEFAConfig section of the Match Field file defines which standardization and match engines will be used by the master index application. By default, the master index application is already configured to use the Sun Match Engine for matching and standardization. For more information, see Understanding Sun Master Index Configuration Options (Repository).
Table 6 lists the elements in the Match Field file that define the match and standardization engine, along with the appropriate values for the Sun Match Engine.
Table 6 Sun Match Engine Standardization and Match Classes
Match Field File Element |
Sun Match Engine Value |
standardizer-api |
com.stc.eindex.matching.adapter.SbmeStandardizerAdapter |
standardizer-config |
com.stc.eindex.matching.adapter.SbmeStandardizerAdapter Config |
matcher-api |
com.stc.eindex.matching.adapter.SbmeMatcherAdapter |
matcher-config |
com.stc.eindex.matching.adapter.SbmeMatcherAdapter Config |
