Developing Sun Master Patient Indexes
Standardization Engine Plug-ins
You can define classes to connect to a custom standardization engine instead of the Sun Match Engine. Specify the names of the custom classes you create in the standardizer-api and standardizer-config elements of the Match Field file. Follow these guidelines when implementing custom standardization engine classes.
