Using the Admin Console
to Administer JBI Components
The Sun Java System (GlassFish) Application Server
includes a web browser-based administrative tool call the Admin Console. The
Admin Console can be used to start and stop domains, configure the server,
deploy applications, and so forth. The Admin Console provides context sensitive
help to assist you with administration tasks.
Starting the Admin Console
To start the Admin Console from NetBeans, right-click the Sun Java System Application Server (or GlassFish V2) node, under Servers
in the Services window, and select View Admin Console from the popup menu.
To start the Admin Console from a web browser located on the same computer
on which the application server is running, open a web browser and type: http://localhost:4848/. This is the configured default. If another
port was specified during the installation of your application server, use
that port number.
To launch the Admin Console on a computer that is not hosting the application
server, open a web browser and enter the following web address:http://<hostname>:<port>where hostname is the name
of the computer on which the application server is running, and port is
the port number for the server.
When you successfully connect, enter the username and password
specified when the application server was installed. The Admin Console's default
username and password are admin (username) and adminadmin (password).
Administering JBI Components from the Admin Console
From the left pane of the Admin Console, select the JBI node to view
the screens available for JBI administration. By selecting the various JBI
nodes in the Application Server tree, you can open JBI administrative screens
to perform the tasks listed in the table below.
JBI Node (select node)
Console Screen
Functions Available
JBI
General (tab)
Provides a summary of the installed JBI Runtime Components, as well
as links to the various component screens.
Configuration (tab)
Configure JBI Runtime: configuration for JBI Component and Library installation
and operation, and JBI service assembly deployment and operation.
Logging (tab)
Configure JBI System Runtime Loggers. Specify log levels for the individual
loggers.
Monitoring (tab)
View runtime monitoring statistics for the JBI Runtime framework and
Normalized Message Router.
Service Assemblies
Service Assemblies
Manage JBI service assemblies. Functions include deploy, undeploy, start,
stop, and shutdown, and allows you to view current state of each service assembly.
Specific Service Assemblies (select a specific service assembly under
the Service Assemblies node)
Provides three tabs that allow you to:
General: View the details for a JBI service assembly.
Descriptor: View the JBI archive metadata 'jbi.xml' contents.
Monitoring: View statistics for a service assembly.
Components
Components
Manage JBI binding components and service engines. Functions include
install, uninstall, upgrade, start, stop, and shutdown, and allows you to
view current state of each component.
Specific Binding Component or Service Engine (select a specific component
under the Components node)
Provides seven tabs that allow you to:
General: View the details for a JBI binding component or service
engine.
Configuration: Configure properties, depending on the component.
Some components do not have configuration properties.
Application: Allows you to select or create a user-named Application
Configuration or Application Variable.
Loggers: Manage the JBI component loggers. Specify log levels
for the individual loggers.
Libraries: View installed Shared Libraries required by this
component.
Shared Libraries
Shared Libraries
Manage JBI Shared Libraries. Functions include install and uninstall,
and provides a description of the installed libraries.
Specific Shared Library (select a specific Shared Library under the
Shared Libraries node)
General: View the details for a JBI shared library.
Components: View components that require this Shared Library.
Custom MBeans
Custom MBeans
Manage custom MBeans that have been deployed to the server. Functions
include deploy, undeploy, enable, and provides the name, implementation class
name, and status of the deployed MBeans.
For more information about using the Admin Console, see the Sun Java
System Application Server 9.1 Quick Start Guide at http://docs.sun.com/app/docs/doc/819-3193/gewgw?a=view.
