Working With the EDM for Sun Master Patient Index
Adding a System Record to a Patient Profile
If a patient has local IDs in addition to those already recorded in the master index application, you can add the local IDs to the patient’s profile by adding a system record to the profile. To add a local ID to a patient profile, you need to specify information such as the system that assigned the local ID, certain demographic information, and the local ID itself. When you add a system record to a patient profile, the survivor calculator determines what changes, if any, should be made to the SBR.
You cannot add a new local ID and system pair to a patient profile if that same local ID and system pair already exists in another patient profile.
ProcedureTo Add a System Record to a Patient Profile
  1. Using one of the search methods described in Searching for Patient Profiles, display the patient profile you want to modify on the View/Edit page.
  2. In the EUID tree in the left portion of the page, select Source Systems.
  3. FollowStep 2: Specify a System and Local ID throughStep 9: Save the Patient Profile.
    When you commit the changes, the page refreshes and the SBR is recalculated based on the new information.
    Note –
    You only need to enter required fields in order to save the new system record. Required fields are indicated by an asterisk (*).
