The Patient EDM provides hyperlinks and command buttons to help you access and move through the Patient EDM pages. When you place the cursor over links and images on the Patient EDM pages, tooltips appear to provide additional information. Information is also provided to facilitate the use of screen readers and other assistive technology.
The actions you can perform on the Patient EDM are grouped into five primary functions: Person Search, Matching Review, History, Create System Record, and Reports. The main menu on all Patient EDM pages provides hyperlinks to each of these functions, as shown in Figure 3. The first page to appear for each function, except the Create System Record function, is a search page. The names of these headings can be modified for your application.
Person Search – The Person Search function allows you to perform a search for a patient profile or set of patient profiles in Sun Master Patient Index. From the associated pages, you can compare two patient profiles, compare records in one patient profile, view all information for one patient profile, update a patient profile, view a transaction history of a patient profile, view a patient’s potential duplicates, or merge patient profiles or system records.
Matching Review – The Matching Review function allows you to perform a search for potential duplicate profiles or for any profiles that were updated by an assumed match. From the associated pages, you can compare, merge, or resolve potential duplicate profiles, and you can view and reverse assumed match transactions.
History – The History function allows you to perform a search for transaction histories or audit log entries. From the Transaction History pages, you can compare information about a patient before and after a transaction occurred, select patient profiles to unmerge, and view a merge history for a patient profile. From associated Transaction History pages, you can unmerge patient profiles. The audit log pages allow you to view information about transactions in which data about a patient was accessed through the Patient EDM.
Create System Record – The Create System Record function allows you to create new patient profiles by creating a system record. When you save the information in the system record, Sun Master Patient Index automatically generates the SBR using the survivor calculator.
Reports – The Reports function allows you to display and print reports about certain transactions performed from both the Patient EDM and from messages sent in from external systems. For information on configuring reports, see Understanding Sun Master Index Configuration Options (Repository). For information about running reports from a command line, see Maintaining Sun Master Indexes.
When you perform a search for patient information using the Person Search, History, or Matching Review functions, information appears in three different pages. The Search page displays the fields you can use as search criteria, the Search Result page displays a list of search result profiles, and the detail pages display the patient profiles you select from the results list. Once you perform a search, you can navigate back through these pages using the hyperlinks provided in a secondary menu below the main menu, as shown in Figure 4. The Matching Review page for potential duplicate searches includes an additional results page called the Associated Records page.
The behavior of the commands on the secondary menu for Person Search, Matching Review, and History is described in Table 2.
Table 2 Secondary Menu Navigational Tools
Menu Option |
Description |
Returns to the original search page with the search criteria filled in. |
Returns to the search results list. |
Detail Page Name |
This is the name of the current detail page. Clicking this menu option does not perform any action unless you perform a merge from the Comparison page. In this case the Comparison option becomes active and returns to the Comparison page. |
This option becomes available when you select Transaction History or Potential Duplicate from the View/Edit page. It returns to the View/Edit page. |
The detail pages display an EUID tree view of the patient profile on the left and the detailed information for the selected tree-view object on the right. If you are viewing a comparison of patient profiles, the tree views appear in the outer sections of the page, with the detailed information in the center. Figure 5 illustrates the View/Edit page and shows the tree view on the left with the person object of the SBR selected. The detailed information displayed on the right is associated with the selected patient profile. When you select a different object from the tree view, the detailed information in the right portion of the page changes accordingly.
