The search pages that appear on the EDM are configured in the Enterprise Data Manager file. The eo-search element, which is nested in the page-definition element of the gui-definition element, contains all of the configuration information for the search pages that appear on the EDM. If you add a new query to the Candidate Select file and you want to access that query from the EDM, you must create a new search page for the query.
Perform any of the following actions to configure the search pages of the EDM. Though some search options can be configured using the Configuration Editor, it is best to modify the XML file directly.
Standard search properties include the type of object returned by each search, the name of the tabbed header for the search pages, and the URL for entry into the search area. These properties apply to all search pages you define, and they can be modified as needed.
In the Projects window, expand the Configuration node in the project you want to modify, and then double-click the Enterprise Data Manager file.
The file opens in the NetBeans XML editor.
Scroll to the page-definition element in the gui-definition element.
In the eo-search element, modify any of the following elements. Do not modify the tab-entrance element.
root-object – The name of the object returned by the search (this must be the name of the parent object).
tab-name – A name for the search pages. This name appears on tab label associated with the search pages on the EDM.
For example:
<root-object>Person</root-object> <tab-name>Customer Search</tab-name> <tab-entrance>/stcedm/EnterEOSearchSimpleAction.do</tab-entrance> |
Save and close the file.
Several search pages are defined by default by the wizard, including the simple lookup page, advanced lookup pages, and the comparison lookup page. You can create additional search pages if needed. Perform the following steps to create a new search page.
The first step in creating a search page is to define certain properties for the appearance of the page, such as its name, how many fields to list in each row, whether to display the EUID or local ID field, and general instructions for the search.
If either the EUID field or the local ID and system fields appear on a search page, any values entered into these optional fields take precedence over information entered into other search fields. For example, if an invalid EUID is entered but valid first and last names are entered, no results are returned due to the invalid EUID. The EUID field takes precedence over the local ID and system fields.
In the eo-search element, create a simple-search-page element.
Make sure the new element falls within the eo-search element, but outside any existing simple-search-page elements. For example:
<eo-search>
<simple-search-page>
</simple-search-page>
</eo-search>
In the new simple-search-page element, create the elements listed in EDM Search Page Definition Elements and enter the appropriate value for each element.
For example:
<eo-search>
<screen-title>Address Search</screen-title>
<field-per-row>1</field-per-row>
<show-euid>true</show-euid>
<show-lid>false</show-lid>
<instruction>Enter address information below.</instruction>
</eo-search>
Continue to Step 2: Define the Search Fields.
Once you define the search page, you must specify the fields that appear on the page. Fields are specified in field groups, and each field group represents a boxed area on the search page. All fields specified for a field group appear in the boxed area named by that group. The box label is defined by the description of the field group.
Complete Step 1: Define the Search Page.
In the new simple-search-page element, create a field-group element.
For example:
<simple-search-page> <screen-title>Simple Person Search</screen-title> <field-per-row>2</field-per-row> <show-euid>false</show-euid> <show-lid>false</show-lid> <field-group> </field-group> </simple-search-page> |
In the new field-group element, create the elements and attributes listed inEDM Search Field Definition Elements and enter the appropriate value for each.
For example:
<field-group>
<description>Address</description>
<field-ref>Address.AddressType</field-ref>
<field-ref>Address.AddressLine1</field-ref>
<field-ref>Address.AddressLine2</field-ref>
<field-ref required=“true”>Address.City</field-ref>
<field-ref>Address.State</field-ref>
</field-group>
Repeat steps 2 and 3 for each field group you want to display on the selected search page.
Continue to Step 3: Specify Search Options.
After you define the criteria fields for the EDM search, you must specify certain options for the search, such as the types of available searches, whether each search is weighted, and whether the search allows wildcard characters.
Complete Step 2: Define the Search Fields.
In the simple-search-page element you created, create a search-option element.
For example:
<field-group>
</field-group>
<search-option>
</search-option>
In the new search-option element, create the elements listed inEDM Search Option Elements and enter the appropriate value for each element.
For example:
<search-option>
<display-name>Alpha Search</display-name>
<query-builder>ALPHA-SEARCH</query-builder>
<weighted>false</weighted>
<candidate-threshold>2000</candidate-threshold>
<parameter>
<name>UseWildCard</name>
<value>true</value>
</parameter>
</search-option>
Repeat the previous two steps for each search type you want to make available on the selected search page.
If you define multiple search option elements, an option button (labelled by the value of the display-name element) appears on the search page for each search option.
The following table lists and describes the elements you can configure in the Enterprise Data Manager file to define the search pages on the EDM.
The following table lists and describes the elements you can configure in the Enterprise Data Manager file to define the fields for each search on the EDM.
Element/Attribute |
Description |
A description of the fields defined for the field-group element. This value appears as a box label for the area of the page that contains the specified fields. |
The simple field names of the fields in the field group using their corresponding objects as the root. For example, the path to the FirstName field in the Person object is “Person.FirstName”. You can define multiple field-ref elements for each field group. |
An indicator of whether the field is required in order to perform a search. Specify any of the following values:
Tip – If you make a field required for a search, it is a good idea to make it required when creating a record as well (by specifying true for the required property for the field in the Object Definition file. Otherwise, searches performed from the EDM could result in no possible matches even though possible matches exist. |
An indicator of whether the field allows you to search by a range of values rather than an exact value. Specify any of the following values:
Tip – You can specify the same field for both exact and range searching by adding it twice to the field list with different attribute values, giving the choice of performing an exact search or a range search from the EDM. For more information about range searching, see Candidate Select Configuration (Repository) in Understanding Sun Master Index Configuration Options (Repository). |
The following table lists and describes the elements you can configure in the Enterprise Data Manager file to define the attributes for each search on the EDM, such as which query to use, whether the search results are weighted, and so on.
Element |
Description |
A short phrase describing the type of search to perform, such as “Alphanumeric Search” or “Phonetic Search”. This appears next to the option button on the search page when multiple search options are defined. |
The type of query to use when this type of search is selected. The value entered here must match a query-builder name in the Candidate Select file. |
An indicator of whether the results of the search are assigned matching probability weights. Specify true to assign matching weights; specify false to return unweighted results. |
The maximum number of records to return for a search. This value must be a positive number, and is only used for blocking queries. Setting the candidate threshold to zero is equivalent to not setting a threshold. |
A list of optional parameters for the search, specified by name and value elements (described below). |
The name of the parameter. Currently, only UseWildCard is available. |
The value of the parameter. For the UseWildCard parameter, this is an indicator of whether the parameter is enabled or disabled. Specify true to allow wildcard characters; specify false to perform exact-match searches. |
Once a search page is defined, it can be modified as needed. You can perform any of the following actions to customize existing search page elements.
Once a search page is defined in the Enterprise Data Manager file, you can modify the search page definition. The following properties can be modified: the name of the search, the number of fields that appear on each row of the search page, and whether the EUID or local ID fields are visible.
Scroll to the eo-search element, and then to the simple-search-page element you want to modify.
In the simple-search-page element, change the value of any of the elements listed in EDM Search Page Definition Elements.
For example:
<simple-search-page> <screen-title>Customer Search</screen-title> <field-per-row>2</field-per-row> <show-euid>true</show-euid> <show-lid>false</show-lid> <instruction>Enter the EUID below.</instruction> </simple-search-page> |
Once field groups and fields are defined for a search page, you can modify the properties of the group and of the fields contained in a group. For more information about the elements that contain the search field configuration, see EDM Search Field Definition Elements.
In the simple-search-page element, scroll to the field-group you want to modify, and do any of the following:
To modify the name of the boxed area in which the field group appears in the EDM, change the value of the description element.
To add a new field to a field group, create and name a new field-ref element in the appropriate field-group element.
To modify the name of a field defined for a field group, change the value of the appropriate field-ref element.
To specify whether a field is required, add a required attribute and specify a value defined in EDM Search Field Definition Elements.
To specify whether a field is used for range searching, add a choice attribute and specify a value defined in EDM Search Field Definition Elements.
To delete a field from a field group, delete all text between and including the field-ref tags that define the field to be deleted.
To delete an entire field group, delete all text between and including the field-group tags that define the field group to be deleted.
Once search options are defined for a search page, you can modify those options if needed. For more information about the elements that define search options, see EDM Search Option Elements.
In the new simple-search-page element, scroll to the search-option element and do any of the following:
To modify the name of the search option button, change the value of the display-name element.
To modify the query type of the selected search, change the value of the query-builder element. The query you specify must match a query defined in the Candidate Select file.
To specify that a search return weighted results, change the value of the weighted element to true.
To specify that a search return unweighted results, change the value of the weighted element to false.
To specify that wildcard characters can be used in a search, change the UseWildCard parameter value element to true.
To specify that wildcard characters cannot be used in a search, change the UseWildCard parameter value element to false.
