Master
Index Locale Codes Properties (Repository)
The following table lists and describes the Configuration Editor fields
and XML elements that define a national domain for normalization or standardization.
In the XML file, each value and locale pair are defined within a locale_codes element. A list of locale_codes elements can
be defined in the locale_maps element.
Configuration Editor Field
XML File Element or Attribute
Description
Value
value
A value that indicates to the standardization engine which national domain to
use to standardize the data. When the value is contained in the Locale Field
Name field (or the locale-field-name element), the standardization
engine uses the corresponding Locale field
(or locale element) to determine the national domain. To specify a default national domain,
enter “Default”.
Locale
locale
A code indicating which national domain to use to standardize data when the
identifying field value in a transaction matches the corresponding Value field
or element. Select one of the following codes.
AU - Australia
FR - France
UK - United Kingdom
US - United States
