The following table lists and describes the elements that configure the parameters for the weighted calculator in the Best Record file.
Element |
Description |
The type of weighted calculation to perform, such as:
The preferred value for the specified quality. This element is only used for the SourceSystem quality and the preference must be a source system code. |
A value that indicates the reliability of the specified quality for determining the best field value for the SBR. You define the scale for the utility values. |
