The Decision Maker is configured in master.xml and defines how to handle certain decision points in the matching process, such as weight thresholds, how to handle multiple records above the match threshold, and whether records originating from the same system can be automatically matched.
You can customize the Decision Maker by performing any of the following actions:
Defining How to Handle Multiple Assumed Matches (OneExactMatch)
Specifying Whether Same System Matches are Allowed (SameSystemMatch)
If you create your own Decision Maker class, you can specify the new class to be used by changing the value of the decision-maker-class element.
In the Projects window, expand the Configuration node in the project you want to modify, and then double-click master.xml.
Scroll to the DecisionMakerConfig element.
Change the value of the decision-maker-class element to the path and name of the new Decision Maker class.
For example:
<decision-maker-class>com.sun.mdm.index.decision.impl.MyDecisionMaker </decision-maker-class> |
Save and close the file.
The OneExactMatch parameter determines how records above the match threshold are processed. This parameter can only be modified directly in the XML file. For more information, see Manager Service Configuration in Understanding Sun Master Index Configuration Options and Understanding Operational Processes, in Understanding Sun Master Index Processing .
Scroll to the OneExactMatch element in the DecisionMakerConfig element.
Change the value of the parameter-value element to true.
For example:
<parameter> <parameter-name>OneExactMatch</parameter-name> <parameter-type>java.lang.Boolean</parameter-type> <parameter-value>true</parameter-value> </parameter> |
Change value of the parameter-value element to false.
For example:
<parameter> <parameter-name>OneExactMatch</parameter-name> <parameter-type>java.lang.Boolean</parameter-type> <parameter-value>false</parameter-value> </parameter> |
The SameSystemMatch parameter determines whether two records with local IDs from the same system can be merged automatically. If your local systems contain reliable data, and rarely duplicate their own records, set this parameter to true. This parameter can only be modified directly through the XML file.
Scroll to the SameSystemMatch element in the DecisionMakerConfig element.
Change the value of the parameter-value element to false.
For example:
<parameter> <parameter-name>SameSystemMatch</parameter-name> <parameter-type>java.lang.Boolean</parameter-type> <parameter-value>false</parameter-value> </parameter> |
For example:
<parameter> <parameter-name>SameSystemMatch</parameter-name> <parameter-type>java.lang.Boolean</parameter-type> <parameter-value>true</parameter-value> </parameter> |
The duplicate threshold is the lowest matching probability weight at which two records are considered potential duplicates of one another. Any records with lower probability weights are not considered to be possible matches. Any records between the duplicate and match thresholds are flagged as potential duplicates, and must be resolved manually. You can configure the duplicate threshold by using the Configuration Editor or by modifying the XML file directly.
In the Projects window, right-click the Configuration node in the project you want to modify, and then click Edit.
The Configuration Editor appears.
In the Duplicate Threshold field, enter the lowest weight at which two records should be considered a potential match.
This value can be any float value lower than the match threshold but higher than the lowest possible matching probability weight.
On the Configuration Editor toolbar, click Save.
Scroll to the DuplicateThreshold element in the DecisionMakerConfig element.
Change the value of the parameter-value element. For example:
<parameter> <parameter-name>DuplicateThreshold</parameter-name> <parameter-type>java.lang.Float</parameter-type> <parameter-value>7.9</parameter-value> </parameter> |
The match threshold specifies the matching probability weight at which two records will be automatically merged, depending on the value of the OneExactMatch parameter and the number of records at or above the match threshold. You can configure the match threshold by using the Configuration Editor or by modifying the XML file directly.
In the Match Threshold field, enter the lowest weight at which two records should be considered a match.
This value can be any float value higher than the duplicate threshold but lower than the highest possible matching probability weight.
Scroll to the MatchThreshold element in the DecisionMakerConfig element.
For example:
<parameter> <parameter-name>MatchThreshold</parameter-name> <parameter-type>java.lang.Float</parameter-type> <parameter-value>28.5</parameter-value> </parameter> |
New parameters cannot be used with the default Decision Maker class and existing parameters should not be deleted. If you create a custom Decision Maker class, you might need to add new parameters or delete existing ones for the new class. You can only perform these tasks by modifying the XML file directly.
Create a parameter element inside the parameters element, but outside any existing parameter elements. Define the following elements:
parameter-name – The name of the parameter.
parameter-type – The type of parameter. Valid values are java.lang.Long, java.lang.Short, java.lang.Byte, java.lang.String, java.lang.Integer, java.lang.Boolean, java.lang.Double, or java.lang.Float.
parameter-value – The value of the parameter.
For example:
<parameters>
<parameter>
</parameter>
<parameter>
<parameter-name>MaxDuplicates</parameter-name>
<parameter-value>5</parameter-value>
</parameter>
</parameters>
To delete one parameter, remove all text between and including the parameter element.
For example, to delete the ExtensiveSearch parameter in the following sample, you would delete the boldface text.
<parameters>
<parameter>
</parameter>
<parameter>
<parameter-name>ExtensiveSearch</parameter-name>
</parameter>
</parameters>
To remove all parameters, remove all text between and including the starting and ending parameters element.
