You can modify the configuration of the fields and objects to specify how they appear on the MIDM pages by modifying midm.xml. You can perform any of the following actions to customize the general appearance of the MIDM. Though some appearance options can be configured using the Configuration Editor, it is best to modify the XML file directly.
Perform any of the following tasks to configure the appearance of the MIDM.
You can define additional objects for the MIDM as long as those objects are defined in object.xml. Each object can only contain the fields that are also defined for that object in object.xml. If you add objects to the object structure using the Configuration Editor, the new objects are automatically added to the midm.xml and you do not need to perform these steps.
In the Projects window, expand the Configuration node in the project you want to modify, and then double-click midm.xml.
The file opens in the NetBeans XML editor.
In the nodes list of the file, create a new node element.
In the new node element, create and define the following elements.
name – The name of the object.
display-order – The order in which the child object types are displayed on the MIDM pages.
For example:
<node> <name>Phone</name> <display-order>3</display-order> </node> |
You might need to renumber any existing objects to keep the numbering sequential.
Define fields for the new object, as described in Adding Fields to the MIDM.
Define the relationship of the object, as described in Defining MIDM Object Relationships.
Save and close the file.
Once an object is defined in midm.xml, you can modify the name or display order. Only modify the name of an object if you modify the corresponding object name in object.xml and the remaining configuration files. Do not change the parent object name. If you modify an object in the object definition on the Configuration Editor, the midm.xml is automatically updated as well.
To modify the object name, change the value of the name element to the new name for the object.
If you change an object name, modify the name in the relationships section as well.
To modify the order in which the object appears on the MIDM, change the value of the display-order element.
If necessary, renumber the order of other child objects so they are sequential.
Once an object is defined in midm.xml, you can remove the object. If the object remains defined in object.xml, then the object is still a part of the enterprise record, but does not appear on the MIDM. Before removing an object from the midm.xml, make sure none of its fields are required in order to create a new record. If you delete an object using the Configuration Editor, the object is automatically deleted from midm.xml.
Scroll to the node element naming the object to delete.
Delete all text between and including the node element for that object.
Using the sample below, to delete the Phone object, delete all the text in the sample.
<node> <name>Phone</name> <display-order>3</display-order> <field> <name>PhoneType</name> <display-name>Phone Type</display-name> <display-order>1</display-order> <max-length>8</max-length> <gui-type>MenuList</gui-type> <value-list>PHONTYPE</value-list> <value-type>string</value-type> <key-type>true</key-type> </field> <field> <name>Phone</name> <display-name>PhoneNumber</display-name> <display-order>2</display-order> <max-length>20</max-length> <gui-type>TextBox</gui-type> <value-type>string</value-type> <input-mask>(DDD)DDD-DDDD</input-mask> <value-mask>xDDDxDDDxDDDD</value-mask> </field> </node> |
If necessary, renumber the order of the remaining objects so they are sequential.
Remove the object from the relationship definition, as described in Defining Relationships Between Master Index Objects.
You can define new fields for an object in midm.xml, but the field must correspond with a field defined for that object in object.xml. Only the fields defined in midm.xml appear on the MIDM windows. If you add a field to the object structure using the Configuration Editor, it is automatically added to midm.xml.
Scroll to the node element that defines the object to which you want to add a field.
In the node element, create a new element named field.
Define and configure the elements listed inMIDM Field Configuration Elements for the new field-field_name element.
For example:
<field <name>LastName</name> <display-name>LastName</display-name> <display-order>2</display-order> <max-length>40</max-length> <gui-type>TextBox</gui-type> <value-type>string</value-type> <is-sensitive>false</is-sensitive> <key-type>false</key-type> </field> |
If necessary, renumber any existing fields to keep the numbering sequential.
The following table lists and describes the XML elements that define the fields that appear on the Master Index Data Manager.
If a field is defined for an object in midm.xml, that field appears on the MIDM windows. If there are any fields defined in the object structure that you do not want to display on the MIDM, you can remove the field definition from midm.xml. If you remove a field from the object structure using the Configuration Editor, it is automatically removed from midm.xml.
If you remove a unique key type field, you must write a custom plug-in that will automatically populate a value into the field in order to meet unique key type field constraints.
Scroll to the field element that defines the field you want to remove.
Delete the field elements that define the field you want to remove.
If necessary, renumber the remaining fields, as described in Modifying MIDM Field Display Options.
Once a field is defined for an object in midm.xml, you can change the name that appears on the MIDM for that field, the location of the field, and the type for the field (such as text box, menu list, and so on).
Scroll to the node element that defines the object that contains the field you want to modify.
Scroll to the field element you want to modify, .
To modify the field label, change the value of the display-name element.
For example:
<display-name>Last Name</display-name> |
To modify the location of the field on the MIDM, change the value of the display-order element.
For example:
<display-order>1</display-order> |
If you change the order of one field, you must change the order of at least one other field to maintain sequential numbering. For example, if you change a field’s location from “2” to “1”, you must then change the location of the field originally specified for location 1.
To modify the type of field to display, change the value of the gui-type element.
For example:
<gui-type>TextBox</gui-type> |
You can enter TextBox (for a standard field), MenuList (for a field whose value must be selected from a drop-down list), or TextArea (for a long field that requires a scrollbar).
Once a field is defined for an object in midm.xml, you can specify or change the name of the drop-down list for the field. If you modify the Code Module for the field in the Configuration Editor, the drop–down list is automatically updated in midm.xml.
Scroll to the node element that defines the object containing the field you want to modify.
Scroll to the field element you want to modify.
Enter the name of the drop-down list in the value-list element.
If the element does not exist for the field, create a new value-list element. For example:
<value-list>STATE</value-list> |
The value of the gui-type element for the field must be “MenuList” if you specify a drop-down list. The value-list element must match a code column value in the sbyn_common_header database table unless the drop-down list is populated by information in the sbyn_user_code table (as they might be for auxiliary IDs). In this case, the value-list element must match a code_list column value in sbyn_user_code.
Once a field is defined for an object in midm.xml, you can change the number of characters that can be entered for the field in the MIDM. You can also specify whether to automatically enter punctuation into a field on the MIDM, but remove the punctuation in the database. If you modify the field's length and format in the object structure using the Configuration Editor, midm.xml is automatically updated as well.
Field length here is constrained by the length of the database column containing the field and the length defined in object.xml.
To modify the length of a field, change the value of the max-length element.
For example:
<max-length>100</max-length> |
To modify the format of the field, change the value of the input-mask and value-mask elements.
If these element do not exist for the field, create new input-mask and value-mask elements. For example:
<input-mask>(DDD)DDD-DDDD</input-mask> <value-mask>xDDDxDDDxDDDD</value-mask> |
If an input mask is defined, in most cases a value mask must also be defined. For information about input and value masks, see MIDM Field Configuration Elements.
Each field on the MIDM requires a specific type of data to be entered. For example, name fields generally require a data string and date fields require a valid date or numeric characters. The type of data defined for each field must correspond with the field type defined for that field in object.xml and in the database. If you modify a field's data type in the object structure using the Configuration Editor, midm.xml is automatically updated as well.
Change the value of the value-type element.
For example:
<value-type>string</value-type> |
You can specify that a certain field or combination of fields be unique in a system object or SBR. An example of a unique fields would be the address type if only one address of each type is allowed. A field’s key type status in midm.xml must match its key type status in object.xml. If you modify a field's key type status in the object structure using the Configuration Editor, midm.xml is automatically updated as well.
To specify that a field must be unique in a system object, change the value of the key-type element to true.
To specify that a field does not need to be unique in a system object, change the value of the key-type element to false.
For example:
<key-type>false</key-type> |
To specify that a combination of fields must be unique for an object rather than just one single field, set the key-type element to true for each field.
You can specify that the values of certain fields be hidden on the MIDM from users without the appropriate access permissions. You can create a custom plug-in that uses the value of the VIP Flag field to determine whether the values of specified fields are hidden (typically in records with a VIP status of “VIP” or “Employee”). In records with any other VIP status, the field values would be visible regardless of whether the field is marked for masking.
This option is only available if the object-sensitive-plug-in-class element in the impl-details section is populated with the custom plug-in class (by default, this element is empty).
To mask field values, you need to define a custom plug-in to implement the masking rules.
Change the value of the is-sensitive element to true.
If the element does not exist for the field, create a new is-sensitive element. For example:
<is-sensitive>true</is-sensitive> |
The is-sensitive element must appear before the key-type element in the field definition.
The relationships in midm.xml are predefined based on the information you provided when you created the object structure definition (object.xml). The relationship structure in midm.xml should match that of object.xml.
Scroll to the relationships element.
Specify the name of the parent object in the name element.
Specify the name of the child objects in the children elements.
For example:
<relationships> <name>Person</name> <children>Alias</children> <children>Address</children> <children>Phone</children> <children>AuxId</children> </relationships> |
To remove a child object from the relationships list, delete the children element defining the object you want to delete.
The local-id element, which is nested in the gui-definition element, defines alternate names for the local ID headings and labels. The name defined here replaces the default local ID heading and field names on all pages, including the search result column names. This element is optional, and if it does not exist the label names default to “Local ID”.
Scroll to the local-id element in the gui-definition element.
Enter the name you want to appear on the MIDM for the local ID fields and headings.
