The MIDM must know the name of the Master Controller interface for the Sun Master Index implementation. Only change this value if you create a custom Master Controller.
In the Projects window, expand the Configuration node in the project you want to modify, and then double-click midm.xml.
The file opens in the NetBeans XML editor.
Scroll to the impl-details element, and then to the master-controller-jndi-name element.
Modify the value of the master-controller-jndi-name element to the name of the Master Controller JNDI class for your server.
For example:
<master-controller-jndi-name>ejb/CustomerMasterController </master-controller-jndi-name> |
Save and close the file.
