Normalization is a part of the standardization process, and is the process of changing non-standard values to a common, standard value. For example, the first name a person uses might not be their given name, but might be a nickname instead. To ensure that a proper match is made between first names, nicknames are normalized based on a configurable list. For example, the common value for “Liz” and “Elizabeth” would be “Elizabeth”.
Normalization is defined in mefa.xml. You can define normalization by either using the Configuration Editor or modifying the XML file directly. The changes you make on the Normalization page of the Configuration Editor are reflected in the normalization structures of mefa.xml. The Configuration Editor provides a simplified way of defining normalization.
Perform any of the following tasks to define normalization:
When you define a field for normalization, you define which field contains the data that needs to be normalized and which field will contain the normalized data. You can also specify one or more variants to use for normalization. A sample normalization structure for the XML file appears at the end of these instructions.
In the Projects window, right-click the Configuration node in the project you want to modify, and then click Edit.
The Configuration Editor appears.
In the object structure in the left pane, add the field that will contain the normalized value.
For more information, see Adding a Field to the Master Index Object Structure.
Click the Normalization tab.
The Normalization page appears.
Click Add.
The Normalized Field dialog box appears.
Enter or select a value for each of the fields described in Master Index Normalization and Standardization Structure Properties.
To specify a variant for the type of data being standardized, do the following:
In the Variant Field Name field, select the field whose value in incoming records will indicate which variant to use.
On the dialog box that appears, enter values in the fields described in Master Index Variants Properties.
Click OK.
If you selected the multiple domain selector, you can add multiple variants; otherwise, you can add one default variant and one field-defined variant.
On the Normalized Field dialog box, click OK.
The new normalization definition appears in the list.
On the Configuration Editor toolbar, click Save.
In object.xml, create the field that will contain the new normalized value. For more information, see Adding a Field to the Master Index Object Structure.
In the Projects window, expand the Configuration node in the project you want to modify, and then double-click mefa.xml.
The file opens in the NetBeans XML editor.
In the structures-to-normalize element, create and name a new group element.
Make sure the new element falls within the structures-to-normalize element, but outside any existing group tags.
In the new group element, define the standardization-type and domain-selector attributes (these are described in Master Index Normalization and Standardization Structure Properties.
If you specified the multiple domain selector for the domain-selector attribute, do the following:
In the group element, create a locale-field-name element and a locale-maps element (described in Master Index Normalization and Standardization Structure Properties and Master Index Variants Properties).
For each variant you want to use, define a locale-codes, value, and locale element in the locale-maps element (described in Master Index Variants Properties).
To specify the source fields to normalize, do the following:
Create a new unnormalized-source-fields element in the group element.
Create a source-mapping element in the new unnormalized-source-fields element.
Define the unnormalized-source-field-name and standardized-object-field-id elements (these are described inMaster Index Normalization and Standardization Structure Properties).
To map the normalized data to destination fields, do the following:
Create a new normalization-targets element under the unnormalized-source-fields element that defines the field to map.
Create a target-mapping element in the new normalization-targets element.
Define the standardized-object-field-id and standardized-target-field-name elements (these are described in Master Index Normalization and Standardization Structure Properties).
Save and close the file.
<structures-to-normalize> <group standardization-type="PersonName" domain-selector= "com.sun.mdm.index.matching.impl.MultiDomainSelector"> <locale-field-name>Person.PobCountry</locale-field-name> <locale-maps> <locale-codes> <value>GB</value> <locale>UK</locale> </locale-codes> <locale-codes> <value>UNST</value> <locale>US</locale> </locale-codes> <locale-codes> <value>Default</value> <locale>US</locale> </locale-codes> </locale-maps> <unnormalized-source-fields> <source-mapping> <unnormalized-source-field-name> Person.Alias[*].FirstName </unnormalized-source-field-name> <standardized-object-field-id>FirstName </standardized-object-field-id> </source-mapping> <source-mapping> <unnormalized-source-field-name> Person.Alias[*].LastName </unnormalized-source-field-name> <standardized-object-field-id>LastName </standardized-object-field-id> </source-mapping> </unnormalized-source-fields> <normalization-targets> <target-mapping> <standardized-object-field-id>FirstName </standardized-object-field-id> <standardized-target-field-name> Person.Alias[*].StdFirstName </standardized-target-field-name> </target-mapping> <target-mapping> <standardized-object-field-id>LastName </standardized-object-field-id> <standardized-target-field-name> Person.Alias[*].StdLastName </standardized-target-field-name> </target-mapping> </normalization-targets> </group> |
The following table lists and describes the Configuration Editor fields and their corresponding XML elements that define the fields to be normalized or standardized in the master index application.
You can specify one or more variants for data to be standardized. A variant is a subset of a data type. For example, if the data type is address, variants are defined for addresses from different countries. The rule set for each country is called a variant. For a single variant, you only need to specify the variant if you need to standardize data that is not from the United States. If you are standardizing data from multiple countries, use the multiple domain selector. This requires that one field in the object structure identify which variant to use for each field that will be standardized. For example, the value of the Country field in a system record could be used to tell the standardization engine which variant to use for a particular set of data. If you specified the multiple domain selector in the domain-selector element, you must also define the identifying field and then map the values that can be populated into that field to their corresponding variant.
The following rules apply to the multiple domain selector:
You can specify a value of “Default” for the identifying field. The corresponding variant is used if the identifying field is blank, contains the value “Default”, or contains a value not defined by any of the value elements.
If a “Default” value is not defined, the system default variant, United States, is used as the default.
For more information about the fields and elements described in the following table, see Understanding the Master Index Standardization Engine.
The following table lists and describes the Configuration Editor fields and XML elements that define a variant for normalization or standardization. In the XML file, each value and locale pair are defined within a locale_codes element. A list of locale_codes elements can be defined in the locale_maps element.
Once you create a normalization definition, you can modify it as needed. Use caution when modifying normalization definitions once a system is in production. This can cause inconsistent match results.
In the Normalization Mappings list, click the definition you want to modify.
Click Edit.
Do any of the following:
Modify any of the fields described in Master Index Normalization and Standardization Structure Properties.
To modify a variant, select the variant under Variants, and then click Edit. Modify either field on the dialog box that appears.
To remove a variant, select the variant under Variants, and then click Remove. Click Yes on the dialog box that appears.
Click OK.
Scroll to the structures-to-normalize element in the StandardizationConfig element.
To modify the normalization type, change the value of the standardization-type attribute.
To change the national domain, change the value of the domain-selector element as described in Master Index Normalization and Standardization Structure Properties.
To modify an existing source field, scroll to the unnormalized-source-fields element in the appropriate group element, and then change the value of any source field elements (these are described in Master Index Normalization and Standardization Structure Properties).
To modify an existing destination field, scroll to the normalization-targets element in the appropriate group element, and then change the value of any target field elements (these are described in Master Index Normalization and Standardization Structure Properties).
If a defined normalization structure is not needed, you can delete the normalization structure from the standardization configuration. If no data requires normalization, you can delete all normalization structures. It is not recommend that you delete a normalization definition once a system is in production. This can cause inconsistent match results.
In the Configuration Editor toolbar, click the Normalization tab.
In the Normalization Mappings list, click the definition you want to delete.
Click Remove.
Do either of the following:
