Understanding Sun Master Index Configuration Options
The mefa.xml File Structure
This topic describes the structure of the XML file, general requirements, and constraints. It also provides a sample implementation.
mefa.xml Description
Table 11 lists each element in mefa.xml and provides a description of each element along with any requirements or constraints for each element.
Table 11 mefa.xml File Structure
Element/Attribute
Description
StandardizationConfig
The configuration information for fields to be standardized. It consists of several structures that define standardization rules for a set of fields. The StandardizationConfig attributes define the module name and Java class, and their default values should not be changed.
standardize-system-object
A standardization structure that defines configuration rules, including normalization, parsing, and phonetic encoding. Each standardization structure contains three primary elements: structures-to-normalize, free-form-texts-to-standardize, and phoneticize-fields. These elements are all required, however any of them can be empty
system-object-name
The name of the object containing the fields defined for standardization. Specifying the parent object allows you to specify any field in any object for standardization. You can also create multiple standardization structures and specify a different object for each structure.
The configuration information for fields that require normalization (but not parsing or reformatting) before being processed by the standardization engine.
group
The national domain, source fields, and target fields for one normalization unit. You can define multiple group elements.
group/standardization-type
The type of standardization to perform on the source fields. This is specific to the type of data being processed and the standardization engine being used. For more information about Master Index Standardization Engine types, see Understanding the Master Index Standardization Engine.
group/domain-selector
The Java class used by the Master Index Standardization Engine to determine the nationality of the data being processed. If no selector is specified, the default is US.
Possible values for the Master Index Standardization Engine include the following:
  • com.sun.mdm.index.matching.impl.SingleDomainSelectorAU
  • com.sun.mdm.index.matching.impl.SingleDomainSelectorFR
  • com.sun.mdm.index.matching.impl.SingleDomainSelectorUK
  • com.sun.mdm.index.matching.impl.SingleDomainSelectorUS
  • com.sun.mdm.index.matching.impl.MultipleDomainSelector
local-field-name
The ePath to an identifying field in the object structure that indicates which of the defined local-codes definitions to use. If no field is specified, the standardization engine defaults to the United States domain. This field must be contained in the object that contains the fields defined for normalization in this structure.
locale-maps
A list of local codes that define how the standardization engine determines which national domain to use.
local-codes
A list of value and locale pairs that indicate the national domain to use based on the value of the identifying field in an incoming message (specified by the local-field-name).
value
A value that, when contained in the identifying field, indicates that the standardization engine will use the corresponding locale element to determine which national domain to use to standardize the data. To specify a default domain, enter “Default” in this element.
locale
A domain code indicating which national domain to use to standardize data when the identifying field value in a transaction matches the corresponding value element.
The supported locale codes for the Master Index Standardization Engine include the following:
  • AU - for Australian data
  • FR - for French data
  • UK - for United Kingdom data
  • US - for United States data
unnormalized-source-fields
A list of source fields to be normalized.
source-mapping
The configuration information for one field in the list of source fields to be normalized.
unnormalized-source-field-name
The ePath of the source field to normalize in the system object (for example, Person.FirstName).
standardized-object-field-id
An identification code that identifies the field to normalize to the standardization engine. This ID is specific to the standardization engine in use and must correspond to a field ID defined by that engine. For more information, see Understanding the Master Index Standardization Engine.
normalization-targets
A list of destination fields to hold the normalized data.
target-mapping
The configuration information for one field in the list of destination fields.
An identification code that identifies the normalized field to the standardization engine. This is specific to the standardization engine in use and must correspond to a field ID defined by that engine. For more information, see Understanding the Master Index Standardization Engine.
standardized-target-field-name
The ePath of the target field in which the normalized value is saved in the system object (for example, Person.Alias[*].StdLastName).
freeform-texts-to-standardize
The configuration information for fields that require parsing or reformatting and, optionally, normalization, before being processed by the standardization engine.
group
The configuration information for the national domain and the source and target fields for one standardization unit. You can define multiple group elements.
The type of standardization to perform on the source fields. This is specific to the standardization engine being used and the type of data being processed. For more information, see Understanding the Master Index Standardization Engine.
The Java class used by the Master Index Standardization Engine to determine the nationality of the data being processed. Possible values are listed below. If no selector is specified, the default is US.
local-field-name
The ePath to an identifying field in the object structure that indicates which of the defined local-codes definitions to use. If this element is not defined, the standardization engine defaults to the United States domain. This field must be contained in the object that contains the fields defined for standardization in this structure.
locale-maps
local-codes
value
locale
A domain code indicating which national domain to use to standardize data when the identifying field value in a transaction matches the corresponding value element. Supported locale codes for the Master Index Standardization Engine are listed below.
unstandardized-source-fields
A list of fields to be standardized.
unstandardized-source-field-name
A field to be standardized. If you define more than one source field in the same standardization unit, the fields are concatenated during standardization with a pipe (|) between lines (for the Master Index Standardization Engine).
standardization-targets
A list of fields in which the standardized data from the source fields is stored.
target-mapping
The configuration information for one destination field in which standardized data from the source field will be stored. One source field will likely have several destination fields.
An abbreviation that identifies the destination field to the standardization engine. This must correspond to a field ID defined by the standardization engine being used. For more information, see Understanding the Master Index Standardization Engine.
The ePath of the destination field in the object where the standardized value will be saved (for example, Person.Address[*].StreetName).
phoneticize-fields
A list of fields to be phonetically encoded.
phoneticize-field
The configuration information for each field to be phonetically encoded, including the encoder to use.
unphoneticized-source-field-name
The ePath of the source field in the system object from which the value to phonetically encode will be retrieved (for example, Person.Address[*].StreetName).
Note –
This can refer to the original field or to a standardized or normalized field.
phoneticized-target-field-name
The ePath of the field in which the phonetically encoded value will be saved in the system object.
phoneticized-object-field-id
A field ID to identify the field to the phonetic encoder. This is not currently used with the Master Index Standardization Engine.
encoding-type
The phonetic encoder to use for this field. This must correspond to the encoding-type configured for the desired encoder in the PhoneticEncodersConfig element.
MatchingConfig
The configuration information for the match string (that is, the fields that are included in the data string sent to the match engine and against which weighting is performed). The attributes of the MatchingConfig element define the module name and Java class, and their default values should not be changed.
match-system-object
The configuration and field definitions for the match string.
object-name
The name of the object containing the fields in the match string. If you specify the parent object, you can specify fields from the parent and any child object in the match string.
match-columns
A list of fields in the match string. This element contains multiple match-column elements.
match-column
The configuration information for one field in the match string. You will use multiple match-column elements.
column-name
The fully qualified field name that defines the location of each field on which to match (for example, Enterprise.SystemSBR.Person.Address.City).
match-type
The type of matching performed on the specified field. This is an ID that is specific to the match engine and identifies the field to the match engine. This value must correspond to a match type defined for the match engine.
match-order
An integer specifying the order in which the field appears in the match string. This element is optional. If no order is specified, matching is performed in the order in which the fields are listed.
MEFAConfig
The configuration information for the components of the matching service. The MEFAConfig attributes (module-name and parser-class) define the module name and Java class, and their default values should not be changed. You should only change the names of the component classes in this section if you created a corresponding custom component.
block-picker
The configuration information for the Java class that chooses which block of criteria defined for the blocking query to use for each match pass.
class-name
The name of the block picker Java class.
pass-controller
The configuration information for the Java class that determines whether the blocking query should continue performing match passes after each match pass is complete.
class-name
The name of the pass controller Java class.
standardizer-api
The configuration information for the standardization engine to use.
class-name
The name of the standardizer API Java class.
standardizer-config
The configuration information for the Java class that provides configuration information to the standardization engine.
class-name
The name of the standardizer configuration Java class.
matcher-api
The configuration information for the match engine to use.
class-name
The name of the match engine API Java class.
matcher-config
The configuration information for the Java class that provides configuration information to the match engine.
class-name
The name of the match engine configuration Java class.
The configuration information for the phonetic encoders used by the master index application. The attributes (module-name and parser-class) define the module name and Java class. The default values should not be changed.
encoder
A list of phonetic encoders used by the standardization engine.
encoding-type
The name of the phonetic encoder, such as NYSIIS, Soundex, or Metaphone.
encoder-implementation-class
The fully qualified name of the Java class that determines the behavior of the phonetic encoder. The following default classes are defined for the Master Index Match Engine.
  • com.sun.mdm.index.phonetic.impl.Nysiis
  • com.sun.mdm.index.phonetic.impl.Soundex
  • com.sun.mdm.index.phonetic.impl.Metaphone
  • com.sun.mdm.index.phonetic.impl.DoubleMetaphone
  • com.sun.mdm.index.phonetic.impl.RefinedSoundex
  • com.sun.mdm.index.phonetic.impl.SoundexFR
mefa.xml Example
Below is a short sample of mefa.xml based on a master index application processing person data. This sample covers the basic elements of mefa.xml, but a production environment would contain several more fields to standardize as well as several additional match string fields.
<StandardizationConfig module-name="Standardization" parser-class=
"com.sun.mdm.index.configurator.impl.standardization.StandardizationConfiguration">
   <standardize-system-object>
      <system-object-name>Person</system-object-name>
      <structures-to-normalize>
         <group standardization-type="PersonName" domain-selector=
          ”com.sun.mdm.index.matching.impl.SingleDomainSelectorUS">
            <unnormalized-source-fields>
               <source-mapping>
                  <unnormalized-source-field-name>
                   Person.Alias[*].FirstName
                  </unnormalized-source-field-name>
                  <standardized-object-field-id>FirstName
                  </standardized-object-field-id>
               </source-mapping>
               <source-mapping>
                   Person.Alias[*].LastName
                  <standardized-object-field-id>LastName
               </source-mapping>
            </unnormalized-source-fields>
            <normalization-targets>
               <target-mapping>
                  <standardized-target-field-name>
                     Person.Alias[*].StdFirstName
                  </standardized-target-field-name>
               </target-mapping>
               <target-mapping>
               </target-mapping>
            </normalization-targets>
         </group>
           "com.sun.mdm.index.matching.impl.SingleDomainSelectorUS”>
               <source-mapping>
                  <unnormalized-source-field-name>Person.FirstName
               </source-mapping>
               <source-mapping>
                  <unnormalized-source-field-name>Person.LastName
               </source-mapping>
               <target-mapping>
                  <standardized-target-field-name>Person.StdFirstName
               </target-mapping>
               <target-mapping>
                  <standardized-target-field-name>Person.StdLastName
               </target-mapping>
         </group>
      </structures-to-normalize>
      <free-form-texts-to-standardize>
         <group standardization-type="Address" domain-selector=
          "com.sun.mdm.index.matching.impl.MultiDomainSelector">
            <locale-field-name>Person.Country</locale-field-name>
            <locale-maps>
               <locale-codes>
                  <value>Default</value>
                  <locale>US</locale>
               </locale-codes>
            </locale-maps>
            <unstandardized-source-fields>
               <unstandardized-source-field-name>
                Person.Address[*].AddressLine1
               </unstandardized-source-field-name>
                Person.Address[*].AddressLine2
            </unstandardized-source-fields>
            <standardization-targets>
               <target-mapping>
                  <standardized-object-field-id>HouseNumber
                   Person.Address[*].HouseNumber
               </target-mapping>
               <target-mapping>
                  <standardized-object-field-id>MatchStreetName
               </target-mapping>
               <target-mapping>
                   StreetNamePrefDirection
                   Person.Address[*].StreetDir
               </target-mapping>
               <target-mapping>
                  <standardized-object-field-id>StreetNameSufType
                   Person.Address[*].StreetType
               </target-mapping>
            </standardization-targets>
         </group>
      </free-form-texts-to-standardize>
      <phoneticize-fields>
         <phoneticize-field>
            <unphoneticized-source-field-name>Person.FirstName_Std
            </unphoneticized-source-field-name>
            <phoneticized-target-field-name>Person.FirstName_Phon
            </phoneticized-target-field-name>
            <encoding-type>Soundex</encoding-type>
         </phoneticize-field>
         <phoneticize-field>
            <unphoneticized-source-field-name>Person.LastName_Std
            <phoneticized-target-field-name>Person.LastName_Phon
            <encoding-type>NYSIIS</encoding-type>
         <phoneticize-field>
             Person.Address[*].StreetNamePhoneticCode
      </phoneticize-fields>
   </standardize-system-object>
</StandardizationConfig>
<MatchingConfig module-name="Matching" parser-class=
 "com.sun.mdm.index.configurator.impl.matching.MatchingConfiguration">
   <match-system-object>
      <object-name>Person</object-name>
      <match-columns>
         <match-column>
           <column-name>Enterprise.SystemSBR.Person.StdFirstName
           </column-name>
           <match-type>FirstName</match-type>
         </match-column>
         <match-column>
           <column-name>Enterprise.SystemSBR.Person.StdLastName
           </column-name>
           <match-type>LastName</match-type>
         </match-column>
         <match-column>
           <column-name>Enterprise.SystemSBR.Person.DOB</column-name>
           <match-type>DOB</match-type>
         </match-column>
      </match-columns>
   </match-system-object>
</MatchingConfig>
<MEFAConfig module-name="MEFA" parser-class=
 "com.sun.mdm.index.configurator.impl.MEFAConfiguration">
   <block-picker>
      <class-name>com.sun.mdm.index.matching.impl.PickAllBlocksAtOnce
      </class-name>
   </block-picker>
   <pass-controller>
      <class-name>com.sun.mdm.index.matching.impl.PassAllBlocks
      </class-name>
   </pass-controller>
      <class-name>
       com.sun.mdm.index.matching.adapter.SbmeStandardizerAdapter
      </class-name>
   </standardizer-api>
   <standardizer-config>
      <class-name>
       com.sun.mdm.index.matching.adapter.SbmeStandardizerAdapterConfig
      </class-name>
   </standardizer-config>
   <matcher-api>
      <class-name>com.sun.mdm.index.matching.adapter.SbmeMatcherAdapter
      </class-name>
   </matcher-api>
   <matcher-config>
      <class-name>
       com.sun.mdm.index.matching.adapter.SbmeMatcherAdapterConfig
      </class-name>
   </matcher-config>
</MEFAConfig>
<PhoneticEncodersConfig module-name="PhoneticEncoders" parser-class=
 "com.sun.mdm.index.configurator.impl.PhoneticEncodersConfig">
   <encoder>
      <encoder-implementation-class>
      </encoder-implementation-class>
   </encoder>
   <encoder>
   </encoder>
</PhoneticEncodersConfig>
