Sun Adapter for Oracle Tutorials
Creating a New Project
First, you create a new project in the NetBeans IDE
ProcedureCreate a Project
  1. Start the NetBeans IDE
  2. Click the New Project icon, or select File -> New Project to initiate the New Project wizard.
  3. In Step 1 of the Wizard, select CAPS -> ESB from the Categories column, CAPS Repository-Based Project from the Projects column, and click Next.
  4. In Step 2 of the Wizard, specify your project name (for this project, use prjOracle_JCD if you are creating the Java Collaboration-based project, or prjOracle_BPEL if you are creating the Business Process-based project), and click Finish.
Next Steps
For your next step, see Creating the OTDs.
