Designing Custom Encoders
Applying Custom Encoding to an XSD
In the absence of a predefined representation of the metadata describing the data format, you must manually create the Abstract Message Definition and apply the Custom Encoder. To begin this process, you must create an XSD and apply the Custom Encoder, as follows:
ProcedureTo Apply the Custom Encoder to an XSD
  1. In your project, right—click to access the project context menu and add a new XML Schema.
    Illustration described in content.
    You will need to develop the XSD node structure to match the parsing of the serialized message stream being processed. This process is described in the topics following this one.
  2. In the resulting XSD, right—click to access its context menu and select Encoder > Apply Custom Encoder.
  3. Once the Encoder has been applied, a special encoding node will automatically be added as a child node of an annotation node.
  4. By right-clicking the encoding node and selecting Properties, you can edit the encoding rules for the individual elements.
  5. After applying the Encoder, the context menu changes as shown in the following illustration. Reapplying the Encoder resets the parameters for all nodes to their default values. The node structure you have created will be preserved.
