Input operators enable you to receive data from external sources.
The External Table Polling Stream operator enables you to retrieve records from an external database table at a specified interval, and to output the records as a stream. The Properties Editor includes a wizard that you use to specify the various properties, including the table columns, the polling interval, and the number of records to retrieve.
After using the wizard, you can update the values for most of the properties from the property editor. However, if you want to add or remove table columns, then you must go through the wizard again.
In the event process, you can link the output of the External Table Polling Stream operator to more than one operator.
One of the properties is the JNDI name of the database resource. Before you deploy the event process, ensure that the JNDI name is configured in the application server to point to a valid database connection. For detailed instructions on configuring JNDI names, see the application server documentation.
Drag an External Table Polling Stream operator from the Palette to the Design view.
Double-click the External Table Polling Stream operator.
The property editor opens.
Click Select Table.
The Select External Table To Poll wizard appears.
In step 1 of the wizard, do the following:
In step 2 of the wizard, do the following:
In step 3 of the wizard, do the following:
The wizard displays the column or columns that you specified in step 2. Select the one or more columns that uniquely identify each record.
The operator uses this information to keep track of the last record that was retrieved. If you do not select any of the columns, then each fetch will start at the beginning of the table.
In the Interval field and drop-down list, specify how often you want to retrieve records from the table.
In the Record Size field, specify the number of records to retrieve each time.
If you want to delete the records from the table after they have been fetched, then select the Delete Records check box.
If you do not select the one or more columns that uniquely identify each record, then selecting the Delete Records check box will ensure that you do not keep retrieving the same records.
In the JNDI Name field, type the JNDI name of the database resource (for example, jdbc/iepseDerbyNonXA).
Click Finish. The property editor displays the values that you specified.
By default, the Preserve Last Fetched Record check box is selected. This setting indicates that if the event process is redeployed, then the operator starts retrieving records where it left off.
If you leave the Preserve Last Fetched Record check box selected, then you must specify a table name in the Last Fetched Record Table field. This table will be created in the IEP database, not in the external database table.
If you want the operator to go back to the beginning of the table instead, then clear the Preserve Last Fetched Record check box.
If you are retrieving records from an Oracle external database, then examine the Data Type column. If a data type is not one of the supported IEP data types, then change the data type to a supported IEP data type. For example, change the DECIMAL data type to the INTEGER data type.
(Optional) In the SELECT area, modify any of the default expressions by adding a SQL function.
(Optional) Click the Documentation tab and supply notes on this component.
Click OK.
The Save Stream and Replay Stream operators are intended to help you perform diagnostics. For example, you can use these operators when the output from an IEP Module project is not the expected output.
You first enable the Save Stream operator to begin saving an input stream to a database table. You then use the Replay Stream operator to replay the events that the Save Stream operator saved to the database table.
Drag a Replay Stream operator from the Palette to the Design view.
Connect the output of the Replay Stream operator to any operator that accepts stream input (for example, the Stream Output operator).
Double-click the Replay Stream operator.
Click Select Table.
The Select Table which has Stream Events wizard appears.
Click OK.
The Replay Stream operator reads events from the database table and sends the events to the next operator.
The Stream Input operator enables you to convert incoming messages to a format that can be used in the event process.
In the property editor, you define a schema that consists of one or more attributes. For example, the schema could consist of two attributes: stock symbol and stock price. Each attribute has a data type, such as INTEGER or VARCHAR.
At runtime, the event process reads the incoming messages from the Normalized Message Router and creates a stream based on the schema that you defined.
You can connect the Stream Input operator to any operator that accepts stream input (for example, the Time Based Window operator).
Drag a Stream Input operator from the Palette to the Design view.
Double-click the Stream Input operator.
If you want to change the default name, then change the value in the Name field.
If you want to define the schema by adding attributes, then do the following:
For each attribute in the schema, click Add Attribute and specify the name, data type, size (if applicable), and scale (if applicable). You can optionally enter a comment.
To remove an attribute from the schema, select the attribute and click Delete.
To move an attribute up or down in the schema, select the attribute and click Move Up or Move Down.
If you want to define the schema by selecting an XML schema definition, then do the following:
Click OK.
The Table Input operator enables you to use a relational database table as input to the event process.
You can connect the Table Input operator to any operator that accepts stream input (for example, the Time Based Window operator).
Drag a Table Input operator from the Palette to the Design view.
Double-click the Table Input operator.
The Details section of the property editor displays the name of the operator and the output schema.
In the Attributes section, you can add or delete attributes for this table input, or move the attributes up or down in order.
In the Data Type column in the Attributes section, select the appropriate data type from the list of data types.
In the Size column, you can specify the size of the data type if, for example, you specify the VARCHAR data type.
Click OK.
