Sun Cluster Data Service for SWIFTAlliance Gateway Guide for Solaris OS
ProcedureHow to Install Sun Cluster HA for SWIFTAlliance Gateway Packages by Using scinstall Utility
Perform this procedure on all of the cluster members that can master Sun Cluster HA for SWIFTAlliance Gateway.
Before You Begin
Ensure that you have the Sun Cluster Agents CD-ROM.
  1. Load the Sun Cluster Agents CD-ROM into the CD-ROM drive.
  2. Run the scinstall utility with no options.
    This step starts the scinstall utility in interactive mode.
  3. Select the menu option, Add Support for New Data Service to This Cluster Node.
    The scinstall utility prompts you for additional information.
  4. Provide the path to the Sun Cluster Agents CD-ROM.
    The utility refers to the CD as the “data services cd.”
  5. Specify the data service to install.
    The scinstall utility lists the data service that you selected and asks you to confirm your choice.
  6. Exit the scinstall utility.
  7. Unload the CD from the drive.
Next Steps
Go to Registering and Configuring the Sun Cluster HA for SWIFTAlliance Gateway.
