This chapter describes the files found after you install Directory Proxy Server, and after you create server instances.
The examples shown in this chapter are for Solaris systems. File extensions and path separators may differ for your operating system. This chapter includes the following sections.
If you installed software from native packages, you may also use the packaging commands on your system to list the files installed. For example, after installing from native packages on Solaris systems, you can obtain a full list for a particular package using the pkgchk -v package-name command.
If you installed software from a zip distribution, find lists of installed files in the install-path/dsee6/data/ directory.
This section describes the file layout you find after installing Directory Proxy Server from the zip distribution. All files locations are relative to the path where you installed the product. For information on default native package installation locations, see Default Paths and Command Locations.
Directory Proxy Server files shared by server instances. This directory houses the following files of interest.
Directory Proxy Server command for local administration. See dpadm(1M).
Directory Proxy Server command for configuration over LDAP. See dpconf(1M).
Directory Proxy Server configuration templates, not intended to be used directly.
Sample Directory Proxy Server plug-ins (currently empty).
Shared Directory Proxy Server libraries, not intended for use directly.
Directory Proxy Server resource files, not intended to be used directly.
Directory Service Control Center agent files shared by multiple Directory Server Enterprise Edition component products. This directory houses the following files of interest.
Command to monitor servers managed through Directory Service Control Center. See dsccmon(1M).
Command to manage the Directory Service Control Center registry. See dsccreg(1M).
Command to set up Directory Service Control Center. See dsccsetup(1M).
Directory Service Control Center agent configuration information, not intended to be used directly.
Shared libraries, not intended to be used directly.
Files shared by multiple Directory Server Enterprise Edition component products. This directory houses the following files of interest.
NSS certificate manipulation command used by other tools, not intended to be used directly.
Command to install and remove software. See dsee_deploy(1M).
Command to base64 encode LDIF attribute values. See ldif(1)
Common agent container files shared by Directory Server Enterprise Edition component products, not intended to be used directly.
Lists of installed files used by the dsee_deploy command, not intended to be used directly.
Libraries shared by Directory Server Enterprise Edition component products, not intended to be used directly.
Directory Server Enterprise Edition online reference manual pages. See also Sun Java System Directory Server Enterprise Edition 6.2 Man Page Reference.
Directory SDK for C header files used by Directory Server Enterprise Edition component products.
Directory SDK for C shared libraries used by Directory Server Enterprise Edition component products.
Directory Server Resource Kit command to compare LDAP entries from two directories. See ldapcmp(1).
Directory Server Resource Kit command to perform LDAP compare operations. See ldapcompare(1).
Directory Server Resource Kit command to delete directory entries. See ldapdelete(1).
Directory Server Resource Kit command to update entries over LDAP. See ldapmodify(1).
Directory Server Resource Kit command to change user passwords. See ldappasswd(1).
Directory Server Resource Kit command to search a directory. See ldapsearch(1).
Libraries used by Directory Server Resource Kit commands, not intended to be used directly.
Java Runtime Environment, not intended to be used directly.
Container for runtime files, not intended to be used directly.
This section describes the file layout you find after creating a Directory Proxy Server instance. The instance-path is the file system path where you created the instance.
Certificate database files, not intended to be used directly.
Server configuration files, not intended to be used directly.
Additional instance configuration, not intended to be used directly.
Default server logs directory. The following files are stored here.
This file records information about the requests processed by Directory Proxy Server. For detail about access logs, see Access Logs for Directory Proxy Server.
This file records errors, warnings, and informational messages logged during Directory Proxy Server operation. For detail about errors logs, see Error Logs for Directory Proxy Server.
Server runtime files directory, not intended to be used directly.
