NAME | Description | Attributes | See Also
Syntax |
enumeration |
Default value |
Default behavior is not defined. |
Must be set |
Yes |
Is modifiable |
Yes |
Is multivalued |
No |
Requires restart |
No |
This property defines the transformation model. The transformation model is determined by the direction of a transformation, in other words, whether the transformation is applied during the request, during the response, or both.
This property can take the following values in addition to the default.
Mapping
Store and forget
Default virtual value
This property is used to configure the following features: virtual-transformation.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Availability |
SUNWldap-proxy |
Stability Level |
Evolving |
dpconf(1M)
