NAME | Description | Attributes | See Also
Syntax |
integer |
Default value |
10 |
Must be set |
No |
Is modifiable |
Yes |
Is multivalued |
No |
Requires restart |
Yes |
This property specifies the initial number of connections that should be made to an LDAP data source to perform read operations.
This property takes an integer.
The value of this property must be at least 0.
This property is used to configure the following features: ldap-data-source.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Availability |
SUNWldap-proxy |
Stability Level |
Evolving |
dpconf(1M)
